what is the widest 18 inch wheel on stock suspension?
what is the widest 18 inch wheel on stock suspension without rubbing?
What's the widest on yyz springs?
This depends highly on the offset of the wheel. There isn't really a specific answer. I know for sure you can fit a 18x9.5 +25 up front on stock. I had them on mine lowered on sportlines for a few weeks. no rubbing up front.
Hey what about the back? Because I trying to running 18x9 +25 on cobalt ss I'm also currently on eibach sportlines
that will fit. it will poke fairly hard, you will need to run either a 205/40 or a 215/40 so it won't wreck your fenders. also put a hockey puck under your bumpstop to prevent it from bottoming out.
Seen 18x10 fronts (unsure of offset) with 275s car had fenders pulled and rolled quite a bit and the pinch seam cut and folded out of the way. Rears I doubt they would fit without serious body work and clearancing.
Here is a thread with my 18x9 +40's and 255/35/18. This is by far the best set of the 4 I have had on my car.
https://www.cobaltss.net/forums/whee...wheels-308775/
DANRICKARD
10-01-2015 12:08 AM
z28addiction
09-28-2015 12:03 AM
