Wheel Help
Okay I have an 07 lsj and i want to upgrade wheels. Im looking at buying an 18x8.5 wheel with a +30 offset, will this fit over the stock lsj brakes or should i do 18x9.5 +35/ or +22?
Any of those setups are going to be very aggressive. I'm running 18x9 +40 on 245/40 tires. The wheel pokes out a bit from the fenders up front with a 5mm spacer to clear my brakes but the slight stretch on the tires pulls it back into the fenders a bit. I've only rubbed a handful of times but my coilovers are pretty stiff. But if you don't mind running a narrower tire like a 225 or 235 with a +30 or 35 offset you might be fine.
