Will these wheels fit around brembos? (Pics on ss/sc)
I am looking at buying wheels but I am worried about the Brembo width combined with the spoke angles/space and how much of a spacer I may or may not need. I was wondering if anyone knew how much wider the Brembos were than SS/SC calipers. I am not talking about length I am talking about how much wider they poke out from the rotors.
My situation: I have a TC with the brembos, I am looking at buying some 18x9 +35 wheels exactly as the ones in these pictures however Honky Boy has the ss/sc calipers and not brembos. Anyone think these exact wheels would fit the brembos by looking at these pics and if not how much of a spacer I may need?
Attachment 7377Attachment 7378Attachment 7379Attachment 7380
Do they make that wheel in +20 or +25?
you know that wheel needs custom drilled and 2craze wont do it right?
Sadly no they make them in 47 and 35... 47 in 5x110 35 in other patterns (Redrilled)
I am hoping to not have to re stud my hubs because I didnt want to run anything over a 5mm spacer.
I'm not getting standard made I am getting another set re drilled, this has already been covered in my original post
yellowsupercharged06: Know of any other 18x9 wheels besides Varrstoens that aren't too expensive to get drilled that will fit??
Since a 10mm spacer would make these +25 would these poke about the same as some of the varrstoen 18x9.5 +25 or +35 with 5mm spacers?
your not going to find a 18x9 wheel in a 5x110 bolt pattern that will fit.
I am not one to get wheels re-drilled ... there is a safety factor that concerns me so i dont have any advice for you on that subject.
What are your intentions that you need such a wide wheel ? Stance .. check out the stance thread im sure they have more info than you need ...
I would just go a 5x114.3 hub swap if i was you and then you can get wheels without a problem.
Does he buy the hubs, drill them, and then just send them to you or do you have to get everything and get it to him? Like I said I have never looked into this other than the ss/sc guy that swapped.
Is there a thread where guys post pics and wheel specs of 5x114.3 wheels that fit?
Edit:
OK What route would you go:
1) Get a second set of hubs re drilled to 5x114.3 with extended lugs installed. 10mm spacer and a 18x8.5 +35 varrstoen es221 and just swap hubs back to stock for stock wheels with winter tires
2) Get a 19mm 5x110 to 5x114.3 adapter and 18x8.5 +35 varrstoen es221 and just remove the adapters to go back to stock wheels for winter?
3) Hub redrill to 5x114.3 Varrstoen 18x8.5 +25 dont worry about the spacer.
Edit:
Edit:
Edit:
