would these fit?
No problem. To be honest, I am unsure if anyone on here has run a 10" wide wheel. I think someone has done 9.5 You might want to add suspension upgrades into that if you're looking to run something like that. I don't think the stock suspension will be able to keep that from rubbing or causing damage.
Sent from my BlackBerry Z30 using the CobaltSS.net App.
so some rolling, remove inside liner of front.... and back too? and some spacers/adapters.
Problem is these cars have a fixed beam in the rear, so it's going to be hard to tuck the tire in to avoid impact with the body lip. I believe some have shimmed the back, but I don't know how far they got to be successful. The front you can camber pretty easy with coils
Delta coupe
09-30-2015 08:11 AM
