S3 kit and belt doesn't fit..
I got the ZZP Stage 3 kit w/ a 2.8 pulley and the "smaller belt"..
They belt is TOO SMALL but on ZZP, it says it will fit 3.1 and smaller.... Does ZZP make any belts that will fit and not cost $100+ or would it be best to just go to CED and get the GM S2 belt? Thanks. |
How small is too small? The GM stage 2 belt is only like 30 dollars and will fit ur 2.8 pulley
Liiike the belt could be half an inch longer nd Itd work. I knoww the gm s2 will fit but I was wondering if ZZP had one that'd work so I could just return mine
i'm pretty sure the "smaller belt" is the gm stage 2 belt.
did you try pushing your tensioner down?
Yea I'm sure the belt they sell is the GM stage 2 belt. I have one and ill let it go for 10 dollars plus shipping
Originally Posted by hawkssoccer11
(Post 5863894)
this. That's the only way you'll get it on.. i stripped the shit out of mine getting the belt back on... ended up having to put a new adjustable tensioner on. |
Yes. I tried everything possible. And I've seen before people said when you get this then order a gm belt bc zzp's isn't actually a gm one.. never really hit me until it didn't fit
Originally Posted by tylerjclance
(Post 5863899)
