proper coolant drain.
Old 02-15-2017, 03:33 PM
brxttz's Avatar
this is probably a dumb question but what is the proper way to drain the coolant when swapping turbos?
thanks.
Old 02-15-2017, 03:39 PM
Kolt's Avatar
Drain the radiator using the drain port and then drain the block using the drain port on the bottom of the water pump. You can use just the water pump but in my experience if the system is still full it sprays everywhere so I drain most of the system via radiator drain, then use the water pump drain to make as little mess as possible.
brxttz (02-18-2017)
Old 02-16-2017, 02:20 PM
umrdyldo's Avatar
I believe this is the water pump drain plug. I haven't done this yet but need to.
brxttz (02-18-2017)
Old 02-18-2017, 10:17 PM
rnjmur's Avatar
If you drain the coolant using the water pump drain plug you need to disconnect the upper radiator hose and be sure to fill coolant through the upper coolant hose before filling the radiator. If you don't you will trap air in the system and it is a BITCH to get it out.
Old 02-18-2017, 11:03 PM
Just pull the lines and let whatever drains drain. No point in draining the entire system.
Old 02-18-2017, 11:32 PM
blu3_v1p3r's Avatar
Brett how did the coolant taste?
Old 02-19-2017, 06:55 AM
63 Nova SS's Avatar
It's kind of a sweet flavor. I didn't drain mine when I changed turbo. But it does drip on you.
Old 02-22-2017, 02:00 PM
brxttz's Avatar
little bit sweet!
Old 02-22-2017, 02:03 PM
umrdyldo's Avatar
I'm not sure that's even required.
Old 02-22-2017, 02:44 PM
cluelessk's Avatar
If you have access to a vacuum filling system use that. It's amazing how much quicker/ idiot proof it is.
Old 02-22-2017, 04:13 PM
umrdyldo's Avatar
I just got one this year for my Nissan. It's ridiculous how easy it is. I don't think it would work through our overflow bottle.
