Sticking brakes
Sticking brakes
soo my rear brakes seem to be sticking in my sedan , my coupe does it too but my sedan gets really bad to the point that when I go to back up the only way to break it is by spinning the crap out of my tires which is burning my clutch... it's quite annoying and I don't feel like replacing a clutch anytime soon, anyone else have this issue? FYI it only happens in the winter on cold days, assuming they're freezing ... should I not use my ebrake ? I neeeeed some advice 😭
I had this problem just over a week ago in my coupe. I couldn't get the rear tire to budge so I ended up taking the wheel off, and manually adjusting the brakes off using the manual adjuster on the brake drum. Took about an hour, and I haven't been using the parking brake since lol
I just put some vice grips on my rear brake lines and took my calipers off, then ziptied the vice grips to one of the holes on the torsion beam to keep them out of the way. I did the same for the e-brake cables.
