Boost Problem please help!!!!!!
Car whistles really loud like theres a boost leak. Leak tested it and it held pressure, but it wont get past 10 psi car normally throws 23 psi any ideas on what could be the issue
Yea maf in stock position. I did a boost leak test tested good so i was guessing the bov was sealing fine. When im driving you can just hear what sounds like a big leak
Don't you need to move your MAF if you run a BOV to a blow through design? Could that maybe cause an issue? Some intercooler pipes, like ZZP's, relocate the MAF and then tune for the BOV. I'm still new at this.
I checked everything it looks fine. Idk what to check anymore intercooler and piping looks fine. Vacuum lines look fine passed leak test. Any ideas maf maybe but theres no code
