Boost Problem please help!!!!!!
Car whistles really loud like theres a boost leak. Leak tested it and it held pressure, but it wont get past 10 psi car normally throws 23 psi any ideas on what could be the issue
So it's whistling and you don't have a boost leak yet it can only hold 10psi? Sure you don't have a charge pipe coupler loose or a map sensor? Does it feel like it's only boosting 10psi?
Don't you need to move your MAF if you run a BOV to a blow through design? Could that maybe cause an issue? Some intercooler pipes, like ZZP's, relocate the MAF and then tune for the BOV. I'm still new at this.
