Car hard to start after filling up with gas
Old 10-16-2016, 09:34 PM
cobaltssdude420's Avatar
Ever since I got my bov and catless dp followed by a tune, I've had to pump the throttle to get the car started. I think it's due to the evap purge solenoid which is no longer needed/in use and have read this issue is called vapour lock. Anyone have any suggestions?
Old 10-17-2016, 08:57 AM
CudaJoe's Avatar
I think Ive heard this has to do with the purge solonoid as well. Why do you think its no longer needed?
Old 10-17-2016, 12:13 PM
Because of the bov. Not too sure how to explain it technically but I trust my tuner. photo858.jpg
Old 10-17-2016, 12:51 PM
Slobodan Milošević
07blackg5's Avatar
here we go. ib4tl
Old 10-17-2016, 12:52 PM
exninja's Avatar
Vapor lock is when the fuel evaporates in the line (usually not an issue in EFI cars). Evap purge solenoid controls the purge of the evap system (also a fuel thing). I don't see why either of those would have anything to do with the BOV.
Old 10-17-2016, 01:11 PM
cluelessk's Avatar
Your tuner is blowing smoke up your ass.
Old 10-17-2016, 01:36 PM
hawkssoccer11's Avatar
go head and trust your tuner over guys who know what the hell they are talking about. pretty soon nobody is going to help you because apparently you and your marvelous tuner know it all.
Old 10-17-2016, 01:55 PM
heeter_33's Avatar
Sounds like your tuner know what he's doing. Just have him retune you and all these issues will go away, when your motor blows.
Old 10-17-2016, 02:32 PM
user 72239's Avatar
you need your EVAP purge solenoid, its the little black box on your intake manifold in that picture. Take it off, and try blowing into it. if you can blow out air, its bad.
Old 10-17-2016, 02:34 PM
user 72239's Avatar
I think hes talking about his boost control solenoid, which is technically not needed after you run a bov. I ran my BOV straight from my intake manifold to the HKS and never had any issues. I had to plug the lower port on the charge piping however
Old 10-17-2016, 02:42 PM
That's why I'm on here to get input lol. I have to go back to my tuner anyway to get the fuel trims fixed.
Old 10-17-2016, 03:12 PM
then why dont you listen to these guys? there should be absolutely no reason as to why that evap solenoid should be unplugged at all.
Old 10-17-2016, 03:26 PM
I didn't ask about if before it was disconnected. Also, I found that waiting a few minutes after I fuel up solves the problem. I'll be sure to mention this to my guy though.
Old 10-17-2016, 03:38 PM
just listen to us thats all were asking. that evap purge solenoid is most likely bad. i replaced one but ill be damned if im gonna sit at a gas station for a couple minutes to just start my damn car when its a super cheap fix.
Old 10-17-2016, 04:09 PM
Just to be sure we're on the same page, the solenoid we're talking about used to be beside the vacuum line in the middle of the manifold where those 3 holes are right?
Old 10-17-2016, 04:12 PM
user 72239's Avatar
Attachment 9725
That is the boost control solenoid.
we are talking about the EVAP Purge solenoid. which is the black box in front of that vacuum line.
Old 10-17-2016, 04:16 PM
Yeah I figured. Sorry for the confusion lol I'm an idiot. Most of the bullshit that I say comes out when I'm bored at work. Glad that's cleared up
Old 10-17-2016, 04:17 PM
user 72239's Avatar
no problem. the way you have your BOV setup is the correct way.
but like I said before, pull that little black box and see if you can blow into it. if you can and air comes out the other side, its bad and you need a replacement.
Old 10-17-2016, 04:21 PM
Cool, thanks
Old 10-17-2016, 04:36 PM
umrdyldo's Avatar
Sometimes they get stuck in the closed position too.
If the evap purge selenoid is over a year old, i'd replace it.
It's $15-20 and 5 min to change. I've replaced 4 or 5 on my car now
Old 10-17-2016, 04:47 PM
Slobodan Milošević
07blackg5's Avatar
this is why my car is evap deleted lol
Old 10-17-2016, 05:59 PM
no_ss's Avatar
X2
Mines deleted and code is deleted. Car runs perfect with out it for me. But I'm also tuned by a reputable tuner.
Old 10-17-2016, 06:01 PM
Slobodan Milošević
07blackg5's Avatar
#weightreduction
Old 10-17-2016, 06:35 PM
no_ss's Avatar
#weightreduction
So jdm
Old 10-17-2016, 08:53 PM
63 Nova SS's Avatar
Originally Posted by no_ss
X2 Mines deleted and code is deleted. Car runs perfect with out it for me. But I'm also tuned by a reputable tuner.
Quick Reply: Car hard to start after filling up with gas
