No_ss build thread
#277
Snail agrees white is a better color on a balt!
KMO43 (12-17-2016)
#282
That white was is sexy as hell!!
#287
Haha I remember that purple
#288
Colin is just a crybaby. Like in the dyno thread
#292
Heres a pic of 235/40/18 on my BCRacing type br
#298
Going wider without getting a wider rim will catch up to you at some point. If you have 9" rims and 9.5 wide tired you are ok. If you have 7.5-8" rims and 9.5 wide tires, the tread will wrap around the sidewall because the rim is too narrow to spread it out. It also won't handle quite as good.check the tread width specs on the tires you are looking at. If they are over 1" wider than your rims, you won't be able to utilize the full width.
