No_ss build thread
I would highly recommend Powell mounts instead. I have a lot of ZZP stuff on my car but after having them And now having Powell the last 2 years, you will be happier with powells.
Heres a pic of 235/40/18 on my BCRacing type br
whyd you switch to 235? Im trying to decide if I want 235/40 or 245/40 on my sedan. Ill be lowered on SSC springs. my current 225/40 aren't much traction and they aren't the smoothest ride.
Going wider without getting a wider rim will catch up to you at some point. If you have 9" rims and 9.5 wide tired you are ok. If you have 7.5-8" rims and 9.5 wide tires, the tread will wrap around the sidewall because the rim is too narrow to spread it out. It also won't handle quite as good.check the tread width specs on the tires you are looking at. If they are over 1" wider than your rims, you won't be able to utilize the full width.
