Eaton Superchargers Modification Guide
Old 02-15-2008, 12:56 AM
  #76
hydraze's Avatar
so, what's the best and safest way to plug those air leakage holes shut???
Old 02-15-2008, 02:02 AM
  #77
Rattlesnake Race Shop
USMCFieldMP's Avatar
Originally Posted by yellowshowbalt
i never ported the scer and its ok .. btw i would like to do a swop with someone for some dyno runs...
meaning if theres a ss out the thats will in to do a base run with there charger then we will put on mine with the same pullys of corse and then run mine just to see the difference.. in boost and iat temps and so forth becouse i know that wasent the right way to do it but the sc that i have was broke in the corner where the triangle is and the little side port was so since it was broke i just cut the rest of it off so i could still use it.. i got the sc for 75.00 becouse it was broke the guy said he droped it and it hit something when it fell ... and he got a new one and i bought that one
You pay for the Dyno Runs... and for the S/C Gasket... and I'll do it. Where you wanna dyno at? I recommend Slowmotion Motorsports in Columbus... but that might be a long drive for you. Cincinnati would probably be 1/2 for the two of us.
Old 02-15-2008, 10:13 AM
  #78
BlackSS/SC's Avatar
OMFG!!! That's SC is looking pretty damn sorry!
Old 02-19-2008, 04:45 PM
  #79
Preowner's Avatar
Always wondered how much boost can be attained due to porting. Is it realy measurable (IE port vs smaller pully), or more like regular(NA) port/polish; where it's good practice to get the most out of other mods?
I have a feeling the answer is more in between.
Edit:
And for that guy hacking up that SC... say what you will but you gotta admit that's alot of boost for $75. I wouldn't be against cutting such corners on an old spare/play vehicle. Though it may need more of a warning caption under it so folks don't go doing such things to perfectly good blowers.
Old 02-19-2008, 04:46 PM
  #80
lsjwannabe's Avatar
you should loose boost, but increase cfm
Old 02-19-2008, 04:50 PM
  #81
Rage915's Avatar
nice write up
Old 02-23-2008, 02:10 PM
  #82
Witt's Avatar
Not without headwork. Airflow and pressure are linear until you do top end modifications.
Old 02-23-2008, 09:55 PM
  #83
TVS_SS's Avatar
or have a significantly better intercooler
Old 03-05-2008, 05:18 PM
  #84
formergto's Avatar
With this talk about JB weld or pressing in peices couldn't you just TIG weld in a plug? I wouldn't think the TIG would heat up enough to distort anything
Old 03-05-2008, 06:06 PM
  #85
TVS_SS's Avatar
TIG = Welding = heating metal to melting point = i shouldnt need to explain.
Old 03-05-2008, 08:50 PM
  #86
formergto's Avatar
I understand what you're saying but just spot welding with a TIG couldnt do that much damage could it?
Old 03-05-2008, 10:34 PM
  #87
jimmyfoxx's Avatar
nice write up.. this is what i am thinkin i am going to do. i love jb weld, i use it all the time at my job. i might get 2 flat 1/8 of in inch think and jv weld that to the leak ports.. that sound like it should hold up? i think it will but i never played around with a sc before.
Old 03-05-2008, 10:37 PM
  #88
seller232004's Avatar
kool
Old 03-05-2008, 10:46 PM
  #89
BeermanSSSC's Avatar
ha great, i can't wait to hear how much louder the supercharger is when they're plugged. mmmhhhahaaa more whine!!!!!!!
Old 03-07-2008, 07:52 AM
  #90
VeNoM0713's Avatar
so what do you suggest we do if we want to plug those silencer holes? im interested in getting that done plus the port/polishing.
Old 03-07-2008, 07:55 AM
  #91
A lot of Grand Prix guys have been telling me to use Quicksteel to seal the holes. I know 2 or 3 guys that run 2.55" pulleys on their Grand Prix's and have had no problems.
Old 03-07-2008, 05:19 PM
  #92
formergto's Avatar
And what is this quicksteel you're talking about?
Old 03-07-2008, 07:08 PM
  #93
http://www.fuckinggoogleit.com/
I believe it to be this, but I am not 100% sure. I am waiting on a reply.
http://www.dual-star.com/index2/Serv...xy%20Putty.htm
Old 03-07-2008, 07:10 PM
  #94
hey maybe you could use Mighty Putty! It can pull a semi and lift a cinderblock.
Old 03-07-2008, 07:15 PM
  #95
TVS_SS's Avatar
Find a raw casting.. weld them in.. reheat the aluminum to proper specs.. then machine the casting.
unfortunately nobody here will be able to do that. Beyond this, there is no "good" way of doing it, all methods are just band-aids.. although some methods are better than others
mighty putty.. lol
Old 03-07-2008, 08:46 PM
  #96
VeNoM0713's Avatar
mighty putty.. lol
so basically.. if you dont do it the proper way, you risk messing up your s/c correct? so for the added sound its not even worth it.. that sucks
hmm.. when you get a reply, let us know.. this looks promising.
Old 03-07-2008, 09:09 PM
  #97
BLK SS/SC's Avatar
i dont plan on doing this but is there any way that the S/C reachs more than 500 for the max rating for the quiksteel
Old 03-07-2008, 09:19 PM
  #98
Are you for real?
500* is hotter than hell. Your S/C isn't going to see that... and if it does... You've got other things to worry about.
Like I said... the GP guys have been running theirs Quicksteeled with 2.55" pulleys for years now.
Old 03-22-2008, 04:47 PM
  #99
ebristol's Avatar
Some quick steel pics. They are not mine.
Old 03-26-2008, 08:45 PM
  #100
anyone done this yet, the pic looks good. trying to find someone on the gtp forums to talk to about it just to get more info before i do it.
Quick Reply: Eaton Superchargers Modification Guide
