Japeatr's knocking at the track rebuild thread
#291
figured it was a time for an update:
well the engines have shipped, arrive in Dallas tomorrow, ill get them this week
started getting some things to put it together
picked up a catback, flywheel bolts, and a new front cover machined for the ATI as my previous one was ate up.
looks like all that's left is a new BOV, electric water pump, and clutch and flywheel, and some various fittings.
JapEatr (02-18-2016)
Haven07 (02-18-2016)
JapEatr (02-19-2016)
#299
got a bunch of the AN fittings for the oil cooler, turbo, and pcv stuff.
still have a few other fittings to go for the EWP setup.
Need to drill/tap the manifold for a PCV line from the head to the Powell separator. I got the manifold gaskets, but need exhaust studs/nuts in order to mount my turbo manifold.
saving up for a clutch before these go in the car.
#300
took inventory of the remaining fittings.
im going to change the oil feed fitting on the turbo to a 1/4"NPT x 4AN elbow, the bottom im going from 10AN adapter to a 45
New exhaust studs from CED will arrive toaday and ill be able to mount the turbo manifold on mine. Blakes is currently mounted.
I got the T3 turbo gaskets as well but am going to switch to studs in the turbo manifold to hold the turbo on
