Japeatr's pics of Powell PCV System install on TVS LSJ
Old 11-11-2013, 10:44 AM
InfraRedline's Avatar
That is pretty reasonable.
Old 01-15-2014, 10:43 AM
bump for research!
Old 01-15-2014, 11:42 AM
armcclure's Avatar
Now that my car is running, we will have results of my turbo variation soon. Best thing about it? It's indifferent to blow through vs draw through.
Old 01-15-2014, 10:17 PM
shadowfaxss's Avatar
At least the line draining the oil from the separator is not your standard rubber line like on the BMW in-line 6. The rubber return line from the oil separator either becomes clogged and/or soft enough to collapse. Common problem with the 3.0.
Nice set up and thanks for sharing!
Old 05-26-2015, 03:04 PM
South Central *********
JapEatr's Avatar
im going to be modifying my setup to draw from the turbo inlet as opposed to the CAI when my car is done with the turbo swap
Old 08-26-2015, 04:53 PM
RedLined's Avatar
I just want to know one thing. HOW DID YOU MATCH THE COLOR OF THE HARROP! I have a tvs with a scratch and would to fix it.
Old 08-26-2015, 05:05 PM
JapEatr's Avatar
haha I have some good resources but both my charge piping and manifold is PC'd the same color of the Harrop
any paint shop or PC shop can match. think It is grey chrome metallic
RedLined (08-26-2015)
Old 08-27-2015, 07:01 PM
Powell Race Parts's Avatar
^^^ this. Julian at Harrop did give me the paint code and we got a match in powdercoat. Pretty decent match.
JapEatr (08-28-2015)
Old 08-28-2015, 11:14 AM
RedLined's Avatar
You wouldn't happen to still have that paint code would you?
Old 08-28-2015, 12:10 PM
^^^ email me I will ask the powdercoater and let you know cheers
Old 08-28-2015, 12:41 PM
  #36
JapEatr's Avatar
id like to know as well
Old 09-01-2015, 12:04 PM
  #37
RedLined's Avatar
www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/harrop-colour-247743/
Kind if old but I stumbled upon this looking for something else.
Old 09-01-2015, 01:59 PM
  #38
JapEatr's Avatar
nice job
Old 09-01-2015, 02:56 PM
  #39
Ukchilll's Avatar
Have you considered a bypass using one way valve to help getting the fresh air back in through the cam cover ??
i found that a bypass really helped to replace the air that is being sucked out as there is to much restriction when the engine changes state and want air in (low load situations )
crude drawing be you get the idea
Old 09-03-2015, 08:46 PM
  #40
LSJ prototype. Now a $395 complete package. In the LNF with our v.3 we eliminate the PCV entirely. This winter I will figure out the same mod for the LSJ laminova inlet manifold.
Micro (08-07-2018)
Old 09-04-2015, 10:20 AM
  #41
JapEatr's Avatar
my new manifold will block the PCV port in the head, should do just that
Old 09-05-2015, 04:08 PM
  #42
nononono. need to get the blowby out of the crank case and both sides of the block is needed. My ,02 c gotta vent the block gotta try to run vacuum in the crank case. etc.
Old 09-06-2015, 09:00 AM
  #43
JapEatr's Avatar
So you think I should tap the manifold for my PCV? Where would i tie it into your kit?
Old 09-07-2015, 03:58 PM
  #44
is it a saab mani? email me send pictures I can discuss ideas cheers
JapEatr (09-15-2015)
Old 09-15-2015, 02:05 PM
  #45
JapEatr's Avatar
I don't think im going to run the Saab mani
Old 08-07-2018, 05:31 PM
  #46
Micro's Avatar
Attachment 14023
I'd like to purchase this. I found some components for the PCV system from Powell Race Parts in the Crate Engine Depot online store, but I couldn't find all of this. How do I arrange to purchase it?
Old 08-07-2018, 06:23 PM
  #47
63 Nova SS's Avatar
Gloria@powellraceparts.com I believe
Micro (08-13-2018)
Old 08-07-2018, 09:23 PM
  #48
63 Nova SS's Avatar
If I remember correctly with mine which was version 2- it came with the separator, a new dipstick with drain back and check valve, new line to manifold and turbo. The newest version taps directly into the manifold/pcv instead and requires modifying the manifold or getting one that's already done, with the kit.
Old 08-08-2018, 06:10 AM
  #49
63 Nova SS's Avatar
Originally Posted by HGT
The drain back for the separator was in the dip stick?
Why would you want to put blow-by contaminated oil back into the crankcase?
It goes through the filter in the separator and recycles back to the pan. That's better than all of it trying to run through the cheap little factory pcv valve oiling up the intake.
Old 08-08-2018, 02:22 PM
  #50
63 Nova SS's Avatar
That's true but not as good as draining it. Diluted oil from Fuel won't get filtered out.
It honestly stays pretty clean (intake) before the separator was put on I had puddles of oil in the intake.
Quick Reply: Japeatr's pics of Powell PCV System install on TVS LSJ
