LSJ Mean Mini Jetboat
Old 02-25-2015, 03:23 PM
AlexBC's Avatar
Question LSJ Mean Mini Jetboat
First, I am going to apologize for a stranger posting about some random ass project. I know how irritating it can be when newbies join a forum and start blasting with problems without doing there own due diligence in research. I'm been digging around with this project since spring, more thoroughly lately.
Now for the project:
Putting an LSJ in front of a two stage hamilton pump in an 11 foot jet boat.
I'm hoping for some help with ECU choice. I have been weighing the advantages of P17 vs E67 vs other stand alones but I was hoping with your wealth of knowledge you may be able to shed some insight.
Typically these boats run a foot pedal, so I can keep the electric one or go LS throttle body with a stand alone. I'm not sure how the stock one will handle the odd splash. What other issues might I run into running the stock ECU running it as a stand alone? Right now I have been running it on the bench with the start relay hot and the fuel pump controlled with the key. I realize this isn't ideal because of fire, if the stock ECU could be up to the job I would pick up HP tuners and disable the VATS. I don't want to start spending on HPTs if a stand alone would be better.
I have spent a ton of time labelling and sorting the harness with the wiring diagrams on Autozone. If anyone wants a complete zip file of .jpegs let me know. I can put them all into a .pdf as well.
As LSJ Masters how would you do it?
Thanks in advance.
Old 02-25-2015, 03:27 PM
yellowsupercharged06's Avatar
in for this !!
LSJ everything lmao amazing
Old 02-25-2015, 03:48 PM
Axelthered05's Avatar
click
Old 02-25-2015, 06:08 PM
mrbelvedere's Avatar
the stock pcm should do the job cool project
Old 02-25-2015, 06:51 PM
AlexBC's Avatar
Oh, forgot to mention it has to run in open loop all the time. You can't run O2's in the marine word with the water injection in the exhaust. I was planning on disabling them via the tuning manual and HP tuners.
Old 02-25-2015, 07:20 PM
LTBALTBMX's Avatar
Haltech platinum sport 1000
Old 02-25-2015, 07:32 PM
Looks nice
Old 02-25-2015, 07:39 PM
Old 02-25-2015, 07:45 PM
Speedytec's Avatar
Where are you injecting that, as the main O2 sensor is located in the manifold. And no problem running the LSJ ecu stand alone, as I have one planted in a rear engined
European Opel Speedster.
Just cut a few unnesessary wires out of the loom and you then need to switch a few things off in HPT. For starters the VATS settings.
The stock pcm can do it to a point but there really is not sufficant tables to really give it a good tune i would go stand alone
Old 02-25-2015, 07:46 PM
Speedytec's Avatar
Originally Posted by mrbelvedere
The stock pcm is not up to the task of speed density go standalone
Just install the MAF.
Old 02-25-2015, 07:58 PM
AlexBC's Avatar
I guess you guys don't see many marine manifolds. Here is mine. The water is injected at the band clamp. It looks like a tube inside a tube. 3" Straight pipe to the transom from there.
Old 02-25-2015, 08:19 PM
LTBALTBMX's Avatar
What's the water injection for? Is it to recapture exhaust power for thrust?
Any reason why you cant vent to atmosphere?
Old 02-25-2015, 08:38 PM
AlexBC's Avatar
As I understand it, in a boat you don't have the airflow you do in a car. Temperatures in the engine bay can get quite hot and melt wiring/coolant lines etc or start a fire. The injected water keeps the exhaust tubing and all the couplers cool so you don't have to run a water jacket all the way to the transom.
Old 02-25-2015, 08:56 PM
i dont think he can run the maf
AlexBC's Avatar
Would an average Joe notice the poor tune or just a well seasoned tuner? Standalone suggestions?
I have been quoted $1500 for a MEFI 4B unit without an LS throttle body. I'm thinking about giving the stock a go then just test some other systems.
Old 02-25-2015, 08:58 PM
AlexBC's Avatar
What issues might I run into? I was looking at using a weld in MAF mount from ZZP with a 3" K&N mounted in a box which is vented outside the engine bay.
Old 02-25-2015, 09:23 PM
i miss understood i thought you were refering that you couldent run the maf or o2 sensor which would put you into speed density
Old 02-26-2015, 11:23 AM
AlexBC's Avatar
I was able to get the manifold on the engine last night. Ran into some issues. Any issues with running a 2.2 thermostat housing and using the heater core spigots to the oil cooler? A 2.2 should clear right?
Old 02-26-2015, 11:52 AM
Administrator
Administrator
Staged07SS's Avatar
Nice project, and great engine choice
Old 02-26-2015, 12:53 PM
insylem's Avatar
Didn't see much room for a fuel tank. Cool Project though!
Old 02-26-2015, 01:27 PM
AlexBC's Avatar
The plan is two 36" x 12" x 6" tanks in the rear along the sides holding 42 litres each (2,592in^3). You really have to drive the boat before finalizing though some like weight in the nose others in the aft.
Old 02-26-2015, 03:53 PM
i doubt the 2.2 stuff will clear your best bet is to plug the heater core hookups
Old 02-26-2015, 03:57 PM
Jedi Master
Tsbbzm's Avatar
Interesting build!
Old 02-26-2015, 05:01 PM
Speedytec's Avatar
I use a (european) 2.2 thermostat housing on my LSJ due to fitment issues, but ditched the LSJ sandwich oil cooler for a different type oil/water cooler. I only used the(modified) seperate LSJ oil cooler attachment assembly to connect my oil hoses to.
Quick Reply: LSJ Mean Mini Jetboat
