only 208whp and 210wtq with intense kit!
Old 03-25-2006, 05:41 PM
Ljavy17's Avatar
Okay, my mods are in my siq. I went to dyno my car today. I only put down 208hp and 210wtq. This was done on a 4wheel drive dyno. He also said that it compares a lot to mustang dyno only a lil bit greedier. Now, im kind of pissed, I never gapped my plugs, what do you guys think. Im kinda sad with the results but i guess its just the kind of dyno it was.
Old 03-25-2006, 05:43 PM
djt81185's Avatar
what are you settings?
Run C1 with the switches at on/off/off/off from left to right. also plugs come gapped at .030. Gap them to .045 for a huge difference.
Old 03-25-2006, 05:46 PM
Ljavy17's Avatar
they left the settings at D,D. that was the best run. I mean man my car pulls so much harder now. at 3000rpm im making 20lbs of tq more than b4 when I had it at c1. Also, How much of a difference can the plugs really make man.
Old 03-25-2006, 05:55 PM
djt81185's Avatar
i made 233 on a mustang dyno with intense stage 3, K&N intake, and a 2.7 inch pulley on c1...0 exhaust work
Old 03-25-2006, 05:56 PM
Ljavy17's Avatar
im really pissed. IM starting to think there was something wrong wid their dyno.
Ljavy17's Avatar
could it be that he didnt calibrate it right, or something, what could it be!
Old 03-25-2006, 05:59 PM
patathSS's Avatar
Did you have a baseline dyno? Its hard to tell without.
Old 03-25-2006, 06:01 PM
djt81185's Avatar
no i have no baseline...but on average a 05 redline makes 185 on a mustang and around 220 on a dynojet
Old 03-25-2006, 06:04 PM
Ljavy17's Avatar
I didnt have a baseline either. .......
Old 03-25-2006, 06:08 PM
Ljavy17's Avatar
now in the bottom my dyno sheet. says. 207hp at 6056rpm. Could that be it, that it didnt read it all the way up to 6500. I mean he was hitting the rev limiter on each run.
patathSS's Avatar
So going off a 185 baseline (which is hard to assume), everything you have added 12.4% power increase over stock. That seems low. Did they do an A/F reading for you?
Old 03-25-2006, 06:16 PM
JCswoosher2's Avatar
There is something wrong with there dyno. the reason they are hitting 270 is because they said they dyno'ed stock at 230. I bought the rev It Up kit expecting stage 1 to give 245 whp. and thats real. I dont know what makes Intense more special. And best part is. Its only stage 1 . Now thats MY OPINION. Intense is cool. But rev It Up seems to have mroe of a long term outlook of support
Old 03-25-2006, 06:22 PM
Ljavy17's Avatar
i get your point man, But I dont want to turn this thread into intense vs revitup. I just want to know if the dyno I worked with was wrong or if Somethings wrong with my car.
Old 03-25-2006, 06:27 PM
ok. I think that there is nothing wrong with the dyno. 208 is odd. but should be around more like 250 whp. so at 208 if installed properly. its the dyno.
Old 03-25-2006, 06:30 PM
Ljavy17's Avatar
when they set the dyno do they set the Rpm so the dyno stops reading at a certain rpm or does it go with the car and it stops reading when the car hits the rev limiter. Why am I seein in the dyno sheet that 207 at 6056.
Old 03-25-2006, 06:50 PM
05_Blue_B10WN_SS's Avatar
Somethings either wrong with the car or the dyno, or possilby both. I dynoed 220WHP & 187 FT/LB TQ stock on a dynojet dyno. I bought the intense kit, and play on putting 260whp down with it. We will see when the time comes. Cares going to dealership tp get a few problems taken care of first
Old 03-25-2006, 07:22 PM
FAST06SS's Avatar
Please elaborate your statement! I gained 40hp from stock. Many others have dynoed 230 or better stock. Guess i should have lied and said i dyno'd 205 stock then i could have said the INTENSE kit added 65hp.
You couldn't find a company more devoted to the "long term" than INTENSE!
Plus knowledgable with SC applications!
Old 03-25-2006, 07:44 PM
280Z1977's Avatar
Stop trolling for Intense. Let their products do the talking. He gave and has his opinion and we all know yours so stop trolling every time someone has a negative OPINION about intense.
To the thread starter, go over your install of the stage 3 kit, then call Intense to double check, and then request another couple of pulls on the dyno and say that you don't believe it was calibrated right and you would like a chance to see if it was the dyno or your car. Good luck.
Old 03-25-2006, 08:01 PM
Eddie's Avatar
always do a before and after dyno at the same shop. that way u know what u were at before and after.
Old 03-25-2006, 08:59 PM
FAST06SS's Avatar
Old 03-25-2006, 09:01 PM
280Z1977's Avatar
That is intelligent.
Old 03-25-2006, 09:04 PM
FAST06SS's Avatar
Thats why the owner and starter of this thread called me and not you for advice! His numbers aren't that bad for a non-dynojet readout.
Go back to your dachsund threads
Old 03-25-2006, 09:14 PM
Bad06SS's Avatar
Yeah, giving stock fuel injectors with a 2.8" pulley (which more than maxes them out) is really looking out for long term.
To the thread starter, I would get dyno'd somewhere else, those numbers seem low to me. Just my opinion.
Old 03-25-2006, 09:17 PM
280Z1977's Avatar
What does that have to do with you being childish???
OHHHHHH, you made fun of the name of my car. Now I must end myself. I see you are just trying to get a rise out of me so that I will make fun of your "badly geared" (heh) 13 second car. Honestly I would hate everyone too, if my car had 270whp and ran 13.5s on good tire. It's cool though, you or someone else will run faster hopefully.
Old 03-25-2006, 09:19 PM
Bad06SS's Avatar
So it's ok for him to voice his opinion and not Rob? Are you mental? JCswoosher gave his opinion, Rob asked him to elaborate, there's nothing wrong with that. Yea, I'm pretty sure he's not trolling when Rob's been talking to him to help him before even coming in thirs thread. We don't need to see any INTENSE vs Revitup threads, they're getting old. The one at fault here is JCswoosher. He took the topic and turned it into an INTENSE VS REVITUP war. Lastly, who are you to come in here and tell anyone what to do? What are you going to do if Rob doesn't stop backing up the company HE'S APART OF? Nothing, exactly. So sit there, shutup, and lets try to help the topic starter with his issue. If you can't do that, I invite you to IDDVII where we can talk about it face to face outside of the track. Vent off.
Quick Reply: only 208whp and 210wtq with intense kit!
