jdbaugh1 official "build" thread
Old 12-17-2016, 06:15 PM
  #51
jdbaugh1's Avatar
Originally Posted by Omiotek
That port job looks rough.....
Lol the camera flash made it look worse than it really is. I thought he did a pretty good job though. It wasn't a port and polish he just ported it out for me. It's up to me to waste my time polishing if I want. As for now I didn't want to run the risk of screwing something up. The pictures were more to demonstrate how much he opened them up than to showcase the surface finish.
Old 01-18-2017, 09:41 AM
  #52
jdbaugh1's Avatar
Installed ZZP 3" exhaust with cat, resonator, and muffler. It is exactly what I wanted. A deeper tone but way quieter than the junk 2.25" magna flow I have had on there for 9 years. It is going to take me a while to get used to it as I usually shift by sound and today I was accidentally hitting the rev limiter because it is so relatively quiet. I highly recommend this setup if you want to be able to move some air without all the rice.
Exhaust cat-back mocked up
Side by side comparison of ZZP humongous resonator and the magnaflow resonator
Way more muffler too
Inside resonator
on the car
https://youtu.be/eAK6aLVDPe4
Old 01-18-2017, 01:56 PM
  #53
royce777's Avatar
looks nice. love seeing 2.2 builds! makes me miss mine.
jdbaugh1 (01-18-2017)
Old 01-21-2017, 10:43 PM
  #54
jdbaugh1's Avatar
Why can't I get the video to show up in thread?
Changed browsers. Couldn't get it to work with firefox
Last edited by jdbaugh1; 01-28-2017 at 08:20 PM. Reason: https://youtu.be/eAK6aLVDPe4
Old 01-28-2017, 08:19 PM
  #55
jdbaugh1's Avatar
Went for a couple pulls to check AFR
Old 02-02-2017, 03:59 PM
  #56
08_Slowbalt's Avatar
You and I have very similar build styles. This is a great build to read through I love it.
jdbaugh1 (02-02-2017)
Old 02-02-2017, 04:32 PM
  #57
jdbaugh1's Avatar
You ought to throw together a build thread so we can check it out.
Old 02-03-2017, 07:33 AM
  #58
I really need to but like you I've had my cobalt since my senior year of high school and the pictures of its progression have been spread out between countless different phones and computers. One day I will get it all together.
Old 02-03-2017, 07:37 AM
  #59
Also, how did you like the those rims? Did decreasing the rotational mass make a notifiable difference? Its not something that seems to be talked about a lot here but I've been cruising Miata forums to pick up tips on shaving weight anywhere I can. I am looking at getting some Konig Backbone rims in 16x7 that weigh in at a little over 15lbs a piece
Old 02-03-2017, 08:31 AM
  #60
jdbaugh1's Avatar
The wheels are TRMotorsport FF10 17X8 wheels weighing in at 17.1 lbs and right now they are on clearance at Tire Rack for $150. That is a light wheel for a cheap price. You can't really compare the weight directly to a different size like 16X7 because this is a bigger wheel. Its hare to say how much I decreased my rotational mass or even if I did because I never weighed the stock steel 15" wheel with tire although it is actually fairly light. I think I stayed pretty close to the same rotational mass while throwing on a much wider tire plus lower profile. I went from 195 width to 245, also from all seasons to Pilot supersports so it made a huge difference. I actually have me steelies on right now and am using them for the winter.
Old 02-04-2017, 02:16 PM
  #61
I cant get over how good your build is lol. I feel inspired now but before I do anything this cool I have a fuel leak to fix. I used to have 17s and I liked them but I want to go to 16s this time around 16x7 with a 205/50R16 to be exact.
jdbaugh1 (04-10-2017)
Old 04-04-2017, 07:46 PM
  #62
theamericono's Avatar
nice build
Old 04-10-2017, 10:17 AM
  #63
jdbaugh1's Avatar
Autocross this weekend was really fun. Glad the season has started again. I love my Bridgestone Potenza RE-71R tires. They blow my Michelin Pilot Super Sports out of the water for grip.
Random picture
Old 04-10-2017, 07:20 PM
  #64
Tehmaster's Avatar
What clutch are you running? I'm having a tough time finding anything that's worth my time.
Old 04-11-2017, 08:09 AM
  #65
jdbaugh1's Avatar
I am actually running the KY stage 1 clutch for the F23 transmission from TTR (KYF23-1). If you look around a bit it would appear this clutch wouldn't be enough but I must not be that hard on it because it hasn't slipped on me yet.
Old 04-11-2017, 09:55 AM
  #66
Tehmaster's Avatar
That sounds right, I didn't want much more than stage one. I had originally planned turbo but decided to go the m62 route as its way cheaper. I'll probably go that way though. Or the exedy stage 2 looks alright.
Old 04-11-2017, 11:03 AM
  #67
jdbaugh1's Avatar
A turbo will yield a higher torque so I would think it would need a better clutch for a given horsepower than the M62. You should be fine with this clutch and the M62.
Old 04-25-2017, 03:15 PM
  #68
FoxTail SS's Avatar
I got your link from Youtube. I'm the guy from the 92' Camaro video.
I really like stuff like this. I actually thought you were the guy who just won FCOTM. However that balt is turbo'd. I'll be following you for sure.
jdbaugh1 (04-25-2017)
Old 05-08-2017, 07:36 PM
  #69
jdbaugh1's Avatar
Placed 5th out of 8 at this one. 2.3 seconds off of the leading 2015 Focus ST driven by the owner of Panda motorworks and I guess the second place ST that was in there had the same mods, same tune, basically same everything according the the Panda motorworks guy. Then I was 1.3 seconds off of a 500 Abarth, and .810 off of fourth place which was another Focus ST. This course was mostly sweepers which my open diff loved
Problem is I noticed my car is drinking oil at a rate that I have to do something now. I know part of it is my PCV configuration. I wish I could find some information on how it routes through the block and how exactly is works. It could be the case that my cylinder bore is just wore and time for a new block. Will be finding out shortly.
Old 05-12-2017, 10:27 AM
  #70
jdbaugh1's Avatar
Made stock lsj h/e crash bar mount brackets out of 1/8" aluminum cut out with a cut off wheel and bent in a vise with a small sledge hammer. I have the flat pattern I would share if anyone ever wanted to duplicate this to relocate the h/e in FRONT of the AC condenser.
Old 05-14-2017, 09:11 PM
  #71
Dude that bracket looks sweet. Id love to see the template for it.
jdbaugh1 (05-15-2017)
Old 05-14-2017, 09:13 PM
  #72
Also, your car looks insanely fun to autox.
Old 05-15-2017, 08:14 AM
  #73
jdbaugh1's Avatar
It is when I can keep it running right! lol I will put up an image of the flat pattern. If someone want's a PDF, DXF, or whatever format, PM me with an email address and I will send you the file. The way I did it I just printed off a 1:1 scale flat pattern, traced it and cut around the line. Depending on what you have access too you can import a DXF format straight into most sheet metal CNC setups. I left the bolt holes that bolt to the h/e off of the pattern to allow some flexibility when positioning but they are fairly easy to mockup with a sharpy especially if you have another set of hands to hold the h/e in place while you mark it. I had to bend the input and output tubes slightly to get adequate clearance from the radiator shroud and front cradle. That is easy enough to do just be easy with them and go slow.
Slowbalt2000 (05-15-2017)
Old 05-15-2017, 10:01 AM
  #74
jdbaugh1's Avatar
Front mount bracket for LSJ stock h/e. Passenger side configuration shown. Drivers side bracket will need to be formed opposite direction. May want to install rubber bushings in between brackets and h/e I'm not sure how much the front crash bar flexes but I was hoping it wouldn't be enough to cause fatigue cracks.
Old 05-15-2017, 10:44 AM
  #75
Shouldnt be hard to make at all. I plan on running two stock heat exchangers this time around.
Quick Reply: jdbaugh1 official "build" thread
