2010+ Future Cruze Discussions Discussions and information related to the upcoming 2010 Chevy Cruze
ZZ Performance buys a Cruze LTZ
Old 12-28-2010, 08:16 AM
  #126
rallycobalt06's Avatar
Originally Posted by Matt M
Something like a stock LNF turbo would be nice. For more power than that, I would compound. Something in the 54-60mm range should work well.
i was just thinking a K04 swap would definitely push the power to 225+whp with the wtq probably around 250 or so.
i wish y'all luck with the Cruze, i'm looking forward to seeing what you guys put out for it.... a Cruze might end up in my driveway in a couple years.
Old 12-28-2010, 08:59 AM
  #127
Ryan@zzp's Avatar
I was thinking more like a 72mm or maybe a 95mm, nothing to big!
Old 12-28-2010, 09:26 AM
  #128
this fkn guy!!
Old 12-28-2010, 05:40 PM
  #129
Matt M's Avatar
Originally Posted by elecblue06
i keep telling vince to do a turbo swap on his hhr and use that turbo on the cruze lol .. i think that would be mighty nice
what kind of numbers you think you could put down with the ss/tc turbo ? think 250 whp or so would be a possibility
With an IC upgrade, 250 shouldn't be a problem. The K04 has an extended tip compressor wheel which should be very efficient at 25. Since it could maintain this pressure at a much lower shaft speed and flow rate than it would need on the LNF, it should actually work well.
Old 12-28-2010, 05:43 PM
  #130
Matt M's Avatar
That's when we 3 stage it. 376 feeds a 252 feeds the stock turbo.
Old 12-28-2010, 05:54 PM
  #131
07SuperchargedSS's Avatar
common GM, throw some incentives my way so I can get mine
Old 12-30-2010, 01:51 PM
  #132
imphat0260's Avatar
ohhhhh, Piece of candy!
Old 12-30-2010, 02:06 PM
  #133
elecblue06's Avatar
I loled at that for reals
Old 12-31-2010, 12:53 AM
  #134
gone_in_10_sec's Avatar
Matt/Ryan - great work on the cruze, good luck!! I can't wait to see what else you guys will do this platform.
Side note, I can't wait until the Buick GS 2012 model hits the floor, I can't imagine what ZZP will do to that thing?? And I'm guessing most of ZZP LNF parts will fit.. that would be nice!!
Old 12-31-2010, 08:32 PM
  #135
Matt M's Avatar
I put up a couple vids in the pic/vid section- https://www.cobaltss.net/forums/pict...s-good-237770/
Old 01-09-2011, 12:47 PM
  #136
4dr-RS's Avatar
I think i want a cruze now, this car is showing so much potential
Old 01-09-2011, 12:59 PM
  #137
elecblue06's Avatar
true.. with just a tune.. it's already as fast if not faster then a 2.4 which is more then most 2.2's can say after full bolt ons and tune
Old 01-09-2011, 01:20 PM
  #138
4dr-RS's Avatar
This is why im impressed, too bad its only semi-auto, but hey i dont mind the manual shifting, and its 6spd its better than dropping from D to L :p
Old 01-09-2011, 06:36 PM
  #139
MP81's Avatar
Wow, this is quite impressive!
Definitely can't wait to see what you guys do next!
Old 01-11-2011, 04:05 PM
  #140
LARRY01Z28's Avatar
I cant wait to get some of these parts on my car.
Old 01-20-2011, 08:08 PM
  #141
LARRY01Z28's Avatar
Any updates yet? think ill try and get ahold of tim.
Old 01-24-2011, 11:28 PM
  #142
4dr-RS's Avatar
This^
UPDATES!! im curious to see what else has been done
Old 01-24-2011, 11:37 PM
  #143
Matt M's Avatar
I am putting together a prototype IC which we will mass produce after all the testing is complete.
Old 01-25-2011, 12:07 AM
  #144
csementuh's Avatar
Is there a Cruze section of the ZZP website yet?
You guys wanna make a blower kit for the 2nd gen Cadillac CTS? It's the same DI 3.6L 6 thats in the new Camaro's so it shouldn't be toooo hard ;-)
Old 01-25-2011, 12:17 AM
  #145
elecblue06's Avatar
wewt hope it goes well and makes some gains
Old 01-26-2011, 07:13 PM
  #146
How much longer until these parts are ready for the Cruze??? Im still debating on keeping my balt and turbo'ing it or getting the cruze and modding that...
Old 01-26-2011, 11:23 PM
  #147
Matt M's Avatar
Intake, o2 housing, and downpipe won't be too far out. Charge tubes and IC will be a little longer.
Old 01-26-2011, 11:36 PM
  #148
conerboner's Avatar
good stuff. Sub'd
Old 01-27-2011, 05:54 PM
  #149
BK05SS's Avatar
best of luck! Keeping an eye on what the performance of the Cruze with the 1.4L-T will end up at
Old 03-06-2011, 04:45 PM
  #150
riko540's Avatar
Same here I am keeping an eye on it for when the Sonic is released.
Quick Reply: ZZ Performance buys a Cruze LTZ
