20,000 rpm eaton blower........Civic si.
Old 07-10-2012, 11:40 AM
  #76
Fsrider's Avatar
There is deff more power down low but still thats how a k20 is. Thats why they rev out to 8400 stock. And vtec kicks in a 6000. Mine kicks in at 3200 tho, so that helps.
Old 07-10-2012, 11:41 AM
  #77
68nova200's Avatar
I dont want to cause an argument, but i prefer usable power before 6000rpm. I think most on here will agree.
Old 07-10-2012, 11:43 AM
  #78
LaserblueSS's Avatar
first off, nice car. sweet set up ya got. secondly, what is the difference between a heat exchanger and an aftercooler?
Old 07-10-2012, 11:47 AM
  #79
Fsrider's Avatar
Yea power every where is nice lol.
Im not one to argue if both sides are understanding of the good and bad of both set ups.
Again thats y why when we get tuned the vtec gets bumped down to 3200. I feel no lack in low end power.
Also i get thru rpms faster then you guys so i get to higher rpms faster so there is less of a time lag. But yes k20s love to be high.
Old 07-10-2012, 11:54 AM
  #80
Dart_SI's Avatar
They have the gearing to easily be in their powerband most of the time. Very close ratios.
Old 07-10-2012, 12:17 PM
  #81
Originally Posted by Fsrider
Heres an ok video before i did all the upgrades. 306hp/219tq. Up to the bottom of 5th (remember its a six speed)
Civic Si :: video-2011-11-07-20-10-13.mp4 video by fsrider_162 - Photobucket
thanks! wow i love how that sounds
Old 07-10-2012, 12:19 PM
  #82
Originally Posted by 68nova200
post one up if you get a chance. I like your setup, but after driving a stock civic with a k20 and seeing zero power until high rpm's im curious to see the tq improvements across the rpm range.
jus do a 4th gear pull from like 25 mph
Old 07-10-2012, 12:25 PM
  #83
Fsrider's Avatar
ok y?
Old 07-10-2012, 12:27 PM
  #84
someone was asking about the power/torque curve. doing a high gear pull shows how it responds. now in ur video i THINK u were in 2nd at about 3000 rpms when you started... and it took off very nicely!
Old 07-10-2012, 12:32 PM
  #85
Fsrider's Avatar
Ok heat exchanger is a general term. Turbos use a air to air heat exchanger to cooler the charge air before the throttle body. An aftercooler cooler is a specific upgrade mostly used on superchargers. It used a small air to water heat exchanger that sits under the supercharger inside the manifold. Then the water coming out of that heat exchanger is cooled by a larger front mount heat exchanger.
This is what it looks like under my supercharger
And this is my front mount.
(the honda sticker is no longer there )
Old 07-10-2012, 12:34 PM
  #86
Fsrider's Avatar
No i was at 70 and i dropped to 3rd and got to the very bottom of 5th. 6th starts at 137 mph.
Old 07-10-2012, 12:35 PM
  #87
user 72239's Avatar
Thats what SS/SC have, its just different. It uses laminova cores, much like the intercooler, which water passes through and then is pumped to a larger FMHE. The problem is the laminova cores can heat soak quickly due to them being stacked on top of eachother.
Old 07-10-2012, 12:38 PM
  #88
Fsrider's Avatar
Mine has zero heat soak it used a bell core that is 3.5 thick. 3-5 gear pulls put my iats to about 130 then it drops back into the 90's in about 3-4 sec's.
Old 07-10-2012, 12:39 PM
  #89
Administrator
Administrator
Staged07SS's Avatar
Your setup shows that with a free flowing head, high rpms, and the proper supporting mods you can make great power with an M62.
The problem with a lot of our members on here is they give up so fast on the M62, because they can't "easily" get to 300whp+ with the stock head, cams, etc. Our head stock does not flow as good as the K20 head stock.
If they were willing to build their setups properly (ported head, cams, nb shafts, etc.) more people would be making decent power with the stock blower.
I think we can learn a lot from your setup, and should pull together and share knowledge and information.
Once again, I thank you for bringing useful/good information to our site.
Old 07-10-2012, 12:40 PM
  #90
user 72239's Avatar
It seems the way you have it, it is much more efficient. However...the blower on the SS is a Roots blower, and the intake manifold is where it compresses the air. Is that a roots or Twin screw? i may have missed that information earlier, and if so...I apologize in advance
Old 07-10-2012, 12:42 PM
  #91
Fsrider's Avatar
Its a roots m62 blower, same as you guys.
  #92
Administrator
Administrator
Staged07SS's Avatar
He's running an M62.
Old 07-10-2012, 12:43 PM
  #93
user 72239's Avatar
I see. well thats awesome you are doing it with a m62.
Old 07-10-2012, 12:44 PM
  #94
Fsrider's Avatar
Thanks a lot man!!
Yea honda made it way to easy for us to make power.
CT stage 2 kit and good i/h/e and you have 300 with a tune.
Old 07-10-2012, 12:53 PM
  #95
Administrator
Administrator
Staged07SS's Avatar
Thanks a lot man!!
Yeah, that's pretty impressive.
I've been sourcing out a rare GM Racing exhaust ported head for my car.
Once I find one, I'm installing S2 cams, valvesprings, bolting it on, and having some fun.
I have a slightly different M62 blower on my car than the general Cobalt crowd, and it helps create a bit more power.
A ported head will really make it shine
Old 07-10-2012, 12:55 PM
  #96
gotcha. wasnt sure how it differed from our intercooler / heat exchanger system. i have no clue what the laminova cores look like, but i really like the system you have set up. very cool. i hear that the laminova cores we have are not as efficient as other aftercooler set ups... kinda sucks.
Old 07-10-2012, 12:56 PM
  #97
user 72239's Avatar
That is what it looks like. the Pass through system is on the right
Old 07-10-2012, 12:57 PM
  #98
zrated89's Avatar
ill be spinning mine to the same 19600 rpms at 8200 rpms i will report back different blower though
Old 07-10-2012, 12:58 PM
  #99
Administrator
Administrator
Staged07SS's Avatar
Our Laminova cores are fine, and do a decent job at removing heat from the charge air.
Although, an intercooler such as the one the OP has might do a little better at cooling.
Old 07-10-2012, 01:01 PM
  #100
Fsrider's Avatar
Yea my aftercooler is a small version of what SVT Cobras use with the blowers they use. Works very good.
I might even have something up my sleeve for you guys. Have to talk to my boss.
Remember lowering your iats will also lower your psi and make it easier for your engine to handle more CFM.
(psi is bad CFM is good)
Quick Reply: 20,000 rpm eaton blower........Civic si.
