LIPSTICK's 800hp first LNF compound turbo/engine build!
Old 12-04-2010, 08:05 PM
  #176
terry11's Avatar
Subd. Thought I was the only one that was putting one of these together
Old 12-19-2010, 02:41 PM
  #177
SKY888's Avatar
this set of wheels will be handling the power....
I received the set of Forgestar F14 Flow-formed wheels about 2 months ago, but didnt open them until recently since I was very busy.
thank you Forgestar Wheels | The Worlds 1st 1 piece lightweight flow formed wheel lineup for the sponsorship!
Matte black 18" x 10" on all corners, only 18 lbs each
they'll be wrapped with Nitto NT05 295/35/18 which will be perfect for my application
Here are some sneak peak photos....
Old 12-19-2010, 02:42 PM
  #178
mkriebs's Avatar
Can't WAIT to see the fatass front's.
Old 12-19-2010, 03:25 PM
  #179
SKY888's Avatar
In regards to powertrain upgrades, Driveshaft Shop will sponsor me a set of:
pair of 600 whp Rear Axle Kit!
I didn't go for the 1000 whp Rear axle kit, since this car will not be an all-out drag car. Car will still remain a daily driver.....and 600 whp is plenty enough for my power goals
Rear axle upgrade includes larger 34 spline high grade aircraft quality center bars, tripod style billet inner CV's with chromoly spline into the differential and a pair of races to convert the outer CV to fit the larger 34 spline bars. Kit also includes boots, clamps and grease.
Old 12-19-2010, 03:38 PM
  #180
mkriebs's Avatar
DSS Axles are the BEST! ran them on the balt, and never had a single issue.
Old 12-20-2010, 05:48 AM
  #181
ralliartist's Avatar
When do you plan on being done with your build? I'm doing a very similar build in terms of compound charging and power level on my LSJ. Would be fun to meet up when we are both done with them?
Old 12-20-2010, 05:58 AM
  #182
SKY888's Avatar
We're planning to be done around end of March 2011.
But who knows what will happen and also some unexpected delays????
We're on unchartered territory......so we'll see.....
Old 12-20-2010, 06:08 AM
  #183
Sounds good. Mine should be complete in August 2011 depending on delays and what-not also.
Old 12-20-2010, 06:47 AM
  #184
SKY888's Avatar
who is doing your build?
the exhaust manifold for the two turbos and fitting them inside the engine bay is one of the tricky parts.
and of course, the tuning.
Old 12-20-2010, 08:37 AM
  #185
uh...........I'm doing my own build. lol
Old 12-20-2010, 09:08 AM
  #186
SKY888's Avatar
I envy you!
You got the skills, knowledge, and tools needed!
I only have very basic skills and tools. I am no welder/machinist/fabricator to create the exhaust manifold.
good luck!
Old 12-20-2010, 10:15 AM
  #187
Originally Posted by SKY888
I envy you!
good luck!
Thanks man. Although, mine isn't quite as complex and complicated as yours.
Since I'm using the stock blower, that is my spool up helper. So I just purchased a zzp turbo manifold for my setup. Easy for me. I'm using the Holset HX40 in my sig, so I simply changed out the exhuast housing to a T3 hotside to bolt to the manifold. I'll probably buy a zzp race intercooler and charge piping along with a zzp downpipe. But I'll end up welding the rest of my exhaust myself.
Good luck to you as well. Yours will be quite the marvel!
Old 12-20-2010, 10:46 AM
  #188
40rty's Avatar
Well, if you guys plan on meeting up, ill be down to join in on the fun as well. Not sure when I'll have mine done but I will be pushing hard on my project once I get to Cali.
Old 12-20-2010, 11:58 AM
  #189
Awesome. Think about how cool it would be. With just the 2 of us, we could make a vid that says, 2 cobalts......over 1200whp. But if we get like 3 or 4..........you see the potential.
Old 12-20-2010, 12:32 PM
  #190
40rty's Avatar
Actually it would be 2 redline and a cobalt. I had an SS/TC.
Old 12-20-2010, 12:35 PM
  #191
spike's Avatar
lurking
Old 12-21-2010, 01:04 PM
  #192
How bout 3 ecotecs? lol
Old 12-21-2010, 03:14 PM
  #193
40rty's Avatar
3 LNF's.
Old 12-21-2010, 03:47 PM
  #194
My car is an LSJ. lol
Old 12-21-2010, 04:19 PM
  #195
SKY888's Avatar
Lipstick's FAT shoes
Nitto just hooked me up with a set of Nitto NT05 295/35/18
They'll be responsible for putting the power to the ground.
fresh from Road Force balancing.....
Old 12-21-2010, 04:27 PM
  #196
elecblue06's Avatar
those rims are AWESOMMME
Old 12-24-2010, 07:21 AM
  #197
mongorat427's Avatar
Wow those wheels look a lot like my Drag DR 31s except they have a single bolt pattern
Old 12-24-2010, 05:43 PM
  #198
tityrous's Avatar
Man it must be nice if i had sponsors My V would be sitting at 1000 RWHP....
Nice progress I love black rims they look great!
Old 12-25-2010, 01:57 AM
  #199
Yea, I'd love to have sponsers.
Old 12-25-2010, 02:28 AM
  #200
mkriebs's Avatar
Well, get out there and get some. Antonio has worked very hard to get what he has right now.
Quick Reply: LIPSTICK's 800hp first LNF compound turbo/engine build!
