LSJ + Air to Air FMIC
Old 03-23-2011, 12:08 AM
100% METH's Avatar
sub 3000 rpm yes; but I believe that has to do w/ the silicon 90* couplers in place of aluminum ones. My 90* couplers at idle are being sucked on rly hard
Old 03-23-2011, 12:33 PM
100% METH's Avatar
Just reserved for 12:30... ill have results posted soon.
Old 03-23-2011, 03:17 PM
100% METH's Avatar
Its a flop ladies n gentlemen...258whp/251ft lbs
here it is compared to my last dyno... on the ported stock manifold.
Old 03-23-2011, 04:12 PM
nizzle's Avatar
I am retarded and I am not sure if I am seeing this right. But, did your power decrease or increase?
Old 03-23-2011, 04:13 PM
100% METH's Avatar
it went down... A LOT
Old 03-23-2011, 04:19 PM
scotch89's Avatar
ouch
good try tho!
Old 03-23-2011, 04:20 PM
nizzle's Avatar
Damn too bad. Sounded like a really "COOL" idea. I was hoping it was gonna work better for you.
Old 03-23-2011, 04:24 PM
Tennpenn83's Avatar
wow... wasn't expecting that far of a drop
Old 03-23-2011, 04:29 PM
100% METH's Avatar
This is my fourth time returning to this dyno fyi...
this dyno is telling the truth...
timing is the same, fueling is the same... nothing changed other than the air to air intake manifold, piping & front mount...
Old 03-23-2011, 06:07 PM
HunterKiller89's Avatar
nothing beats out air-water
at least, not until you heat soak, but we already know that isnt an issue for you steve
Old 03-23-2011, 06:19 PM
  #36
crazywhiteboy89's Avatar
Originally Posted by euthanasia
no comment at the moment lol.
dam let me know i want
Old 03-23-2011, 06:24 PM
  #37
defo98's Avatar
after it just dropped his power almost 50whp?
Old 03-23-2011, 06:30 PM
  #38
i seen one of the cars at smg running this about 6 months ago. good gains in lower iats
Old 03-23-2011, 07:16 PM
  #39
well this on a aftermarket blower i want to see price and if how it would work on a stock blower
Old 03-23-2011, 07:30 PM
  #40
blackbird's Avatar
Probably worse losses as a percentage of power being produced. Positive displacement blowers don't work very well on setups such as this when you add a lot of extra volume between the blower discharge and the cylinder head. If your liquid-to-air setup is heat soaking or can't remove enough heat I could see a giant air-to-air intercooler cooling the charge better but IATs alone don't tell the whole story. You have to look at the density of the intake charge and pressure drop that occurs when switching to that type of setup.
Old 03-23-2011, 07:32 PM
  #41
100% METH's Avatar
You rly believe 2.5 pipe or a m62 on my current 2" intercooler piping is going to magically make back 50 horses? Save your pennies man and have euthanasia port a head for you.
@casey: im swapping back to the ported lower mani this friday. Jr is going to do a little smoothing to the inlet and v of the mp90.
Old 03-24-2011, 04:38 AM
  #42
good ****.
You should start looking around for a head to port
Old 03-24-2011, 12:55 PM
  #43
ralliartist's Avatar
yay, at least there is proof now. Put this dead horse in the ground finally after all these years.
Old 03-24-2011, 01:47 PM
  #44
100% METH's Avatar
Well i think ive accomplished my goals...
Going to have a back to stock sale starting this friday night
Old 03-24-2011, 02:02 PM
  #45
ecot3c inside's Avatar
hrrmm, m90 intake adapter?
Old 03-24-2011, 02:18 PM
  #46
100% METH's Avatar
hit up Euthanasia, he makes the adapters for $$$
haha yup!
Old 03-24-2011, 02:31 PM
  #47
jonathan923's Avatar
i think there was a reason for why gm didnt do it like that at first, but either way now we all know. in for any further notices.
Old 03-24-2011, 06:22 PM
  #48
InfraRedline's Avatar
Well then when you come up here we will have a 96-98 cobra vs. 96-98 cobra faceoff if thats the route you go
Old 03-24-2011, 07:34 PM
  #49
100% METH's Avatar
Haha if i can find one that i like, sure.
Old 03-24-2011, 09:28 PM
  #50
383_Stroker's Avatar
Good effort ..
Quick Reply: LSJ + Air to Air FMIC
