SCcobaltSS Twincharge Build
#77
#81
He tried a variation of different things. Removed the heat sheild and may have modified the mount a little.
I am just hoping the 1.06 a/r housing has the 3" opening and doesnt flare.
Garrett GT3076R (GT3037) Dual Ball Bearing Turbo Customizable
Check out the bottom set of pictures third from the right. That is the housing I need! I wonder what the 1.06 looks like. I see it comes in the .82 but I dont know if that will spool too quickly...
Edit:
Looking at my options on garretts website I can get these housings of 1.06 a/r. All the options have three types.
740902-1
740902-7
740902-13
I dont know if one of these will have the non-flared housing or not but I would think it would.
Edit:
740902-1
740902-7
740902-13
#84
Alright got little things here and there finished last night this is what I have left:
Wire Gauge
Bolt down rest of header (3 more bolts)
Mount Breather
Run Return oil line (line needs to be sized)
Put stock sized pulley and belt on
Cut intake a little to fit then clean
Drill WB bund out (some metal in the way)
Install bumper
Retorque bolts
Change oil
Add water
Should finish tonight within a couple hours.
Wire Gauge
Mount Breather
Install bumper
Retorque bolts
Change oil
Add water
#87
Wire Gauge
Mount Breather
Install bumper
Retorque bolts
Change oil
Add water
Wire Gauge
Mount Breather
Install bumper
Retorque bolts
Change oil
Add water
#88
#91
#96
Finished the build except welding the charge pipes. I am still having an issue with welder so I will go easy on the car, if I even drive it.
Pictures will be updated tomorrow.
I did some final checks, tq on the bolts, oil and water lines. Everything good, go to start it. Nothing.... Battery is dead. I dont have anyway of jumping it right now so it will have to wait till tomorrow.
#97
towing, lol. I don't know if anyone remembers this......
http://s36.photobucket.com/albums/e3...%20Track%20day
#98
I'm too JDM for you
#99
#100
Only thing I need for the car is new fast clips. I broke two of them during the process..
