"SHORT BUS" LNF Sedan Build Thread
#54
Let me know if you want a reinforced bellhousing for your build. Definitely sounds like you cracked the bell housing pinion loop which means the output shaft is moving away from input shaft and diff gear. The reinforced bell housing will prevent this. When this happened to my trans, it also busted 1st gear synchro and chewed up the output shaft. Worst part is when that trans fluid absorbs into clutch disc as Ray mentioned. It needs replaced or new disc pads unfortunately. And 150$ for a 4.05 LSD HOLY CRAP! Cheaper than the F23 open diff
PLEASE post a picture of where it broke if you don't mind.
LNFwagonSS (11-15-2016)
#57
Got the transmission out today. Case is cracked . Whatever caused it to crack I have no clue. This was a used non LSD 4.05 trans that I had with already 120k miles on it.
DO NOT LAUNCH ON SLICKS WITH A NON LSD TRANS . Lol
New trans
New trans!
Cracked to the left of the bellhousing.
New trans
New trans!
#59
Well right now I'm just waiting on parts. Transmission is all cleaned up and ready to go in.
Ordered a new gmpp clutch from CED, clutch pipe, tob, axle seals, and trans fluid. Found some on eBay for 20$ a quart!
#61
UPDATE!!! the clutch came in around 5:30pm yesterday evening.
Started installing it and the new transmission around 10am, finished up around 1pm. This transmission is very smooth and makes no winding noise's at all.
#62
UPDATE!!!!!!
I Spoke with bill Hahn today in regards to my turbo kit. It going to ship on tuesday and be here by friday!!!
will get it installed once it gets here and tune it!
will post dyno sheets and numbers.
#68
I just start up top and remove everything that I can before I jack the car up, then remove everything that needs to come out to take the subframe out, then starter comes out, then bottom bellhousing bolts and it's out.
#72
UPDATE!!!!
Today I got off of work early,so I decided to start on the Hahn racecraft turbo upgrade.
Also since the stock turbo is on its last leg,it's the perfect time.
I'm about 75% done with the install.
Tomorrow all I have to do is put the o2 housing, wastegate, and downpipe on, run 3 vacuum lines, install maf into lower cp, and hook the oil lines up.
I must say, the kit goes in fairly well, I have no complaints. The firewall was given ana torture adjustment via ball peen hammer tho to clear the turbo haha.
If anyone else installs this kit, you can assemble the manifold and downpipe adapters both to the turbo before putting it in the car, it makes like much easier.
Here are a few pictures .
#73
Nice! Are you worried at all about pulling in hot air from down around the motor to supply it to the turbo? Probably won't be bad once you get going, but off idle it maybe high.
I wouldn't drive down a dusty road either as I'm sure dust and grit wouldn't be good for that compressor wheel. Looks good!
#74
#75
UPDATE!
Finished up tonight! Took my time on it today and made sure everything was perfect!
Overall, the Hahn kit works great, and fitment was awesome. 2 bolts where hard to get to, but still manageable.
The only thing I had trouble with is figuring out the best way to clock the turbine and compressor size to line up clearanc for the oil feed and drains, and also for the upper charge pipe to connect.
As you will see in the picture, it sits a little crooked, but I plan on changing that out for a better one soon.
I'm pretty sure I'm the first LNF in the country with Hahn's new setup on their car and running! Ready to start tuning on this basemap and make some power!
