"SHORT BUS" LNF Sedan Build Thread
Old Nov 15, 2016 | 05:49 AM
  #51
63 Nova SS's Avatar
$150? That's ridiculous. Hope your clutch didn't get soaked. Still think you need to get a cryo heat treated trans for the bigger turbo with how many passes that car is going to see.
Old Nov 15, 2016 | 08:51 AM
  #52
SS_Bananna's Avatar
Yeah I hope not! We'll see when I drop the trans today
Old Nov 15, 2016 | 08:53 AM
  #53
SS_Bananna's Avatar
When the money is right I will get a cyro'd Trans.
Old Nov 15, 2016 | 11:13 AM
  #54
LNFwagonSS's Avatar
Let me know if you want a reinforced bellhousing for your build. Definitely sounds like you cracked the bell housing pinion loop which means the output shaft is moving away from input shaft and diff gear. The reinforced bell housing will prevent this. When this happened to my trans, it also busted 1st gear synchro and chewed up the output shaft. Worst part is when that trans fluid absorbs into clutch disc as Ray mentioned. It needs replaced or new disc pads unfortunately. And 150$ for a 4.05 LSD HOLY CRAP! Cheaper than the F23 open diff
PLEASE post a picture of where it broke if you don't mind.
Old Nov 15, 2016 | 11:34 AM
  #55
SS_Bananna's Avatar
I definitely will post a picture of where it broke. I'all have it out this afternoon around 4pm.
Update coming
Old Nov 15, 2016 | 01:21 PM
  #56
63 Nova SS's Avatar
I definitely will post a picture of where it broke. I'all have it out this afternoon around 4pm. Update coming
I'm surprised you haven't come up with a quick change setup for some of your stuff as much as you are under the hood.
I pulled motors and trans so much in the nova that I installed a bunch of ball valves so I didn't have to drain/lose fluid every time I did work.
Old Nov 15, 2016 | 08:13 PM
  #57
SS_Bananna's Avatar
Got the transmission out today. Case is cracked . Whatever caused it to crack I have no clue. This was a used non LSD 4.05 trans that I had with already 120k miles on it.
DO NOT LAUNCH ON SLICKS WITH A NON LSD TRANS . Lol
New trans
New trans!
Cracked to the left of the bellhousing.
Old Nov 16, 2016 | 06:27 AM
  #58
63 Nova SS's Avatar
If anyone will find out the weak point it would be you at the track on slicks. You never know what shape it was in before you through it in.
Would love to start with new everything.
Old Nov 16, 2016 | 09:13 AM
  #59
SS_Bananna's Avatar
Well right now I'm just waiting on parts. Transmission is all cleaned up and ready to go in.
Ordered a new gmpp clutch from CED, clutch pipe, tob, axle seals, and trans fluid. Found some on eBay for 20$ a quart!
Old Nov 17, 2016 | 11:58 AM
  #60
SS_Bananna's Avatar
Axle seals and one quart of trans fluid came in. Today. Still waiting on a clutch!!
Old Nov 19, 2016 | 11:42 PM
  #61
SS_Bananna's Avatar
UPDATE!!! the clutch came in around 5:30pm yesterday evening.
Started installing it and the new transmission around 10am, finished up around 1pm. This transmission is very smooth and makes no winding noise's at all.
Old Nov 28, 2016 | 06:41 PM
  #62
SS_Bananna's Avatar
UPDATE!!!!!!
I Spoke with bill Hahn today in regards to my turbo kit. It going to ship on tuesday and be here by friday!!!
will get it installed once it gets here and tune it!
will post dyno sheets and numbers.
Old Nov 28, 2016 | 07:17 PM
  #63
cw383's Avatar
Wait 3 hours? WTF!!! I'm impressed!
Old Nov 28, 2016 | 07:58 PM
  #64
63 Nova SS's Avatar
I will be really impressed if it makes it to your doorstep Friday. Hope it does.
Old Dec 6, 2016 | 01:17 PM
  #65
SS_Bananna's Avatar
UPDATE
Well the kit finally came in yesterday!
Old Dec 6, 2016 | 01:36 PM
  #66
The kit looks nice man! Hope it makes the power your looking for
Old Dec 6, 2016 | 08:53 PM
  #67
63 Nova SS's Avatar
Can't wait to see how your car does with this setup. Sorry to see your brother bailing on the platform for the easy rwd life.
Old Dec 7, 2016 | 08:44 PM
  #68
SS_Bananna's Avatar
Should definitely make the power I want. With that awesome external gate!
Old Dec 7, 2016 | 08:45 PM
  #69
SS_Bananna's Avatar
Idk if he is yet or not, having a weird problem controlling the maf frequency with the zfr.
Old Dec 9, 2016 | 04:10 PM
  #70
T-Man's Avatar
What turbo did you wind up choosing with the HAHN kit?
Also would love to know how you're dropping/installing the trans so quickly! LOL
Asking for a friend.... Who is pulling the trans from a certain wrecked car as a spare...
Old Dec 10, 2016 | 11:49 PM
  #71
SS_Bananna's Avatar
I went with the 5858CEA
I just start up top and remove everything that I can before I jack the car up, then remove everything that needs to come out to take the subframe out, then starter comes out, then bottom bellhousing bolts and it's out.
Old Dec 11, 2016 | 12:09 AM
  #72
SS_Bananna's Avatar
UPDATE!!!!
Today I got off of work early,so I decided to start on the Hahn racecraft turbo upgrade.
Also since the stock turbo is on its last leg,it's the perfect time.
I'm about 75% done with the install.
Tomorrow all I have to do is put the o2 housing, wastegate, and downpipe on, run 3 vacuum lines, install maf into lower cp, and hook the oil lines up.
I must say, the kit goes in fairly well, I have no complaints. The firewall was given ana torture adjustment via ball peen hammer tho to clear the turbo haha.
If anyone else installs this kit, you can assemble the manifold and downpipe adapters both to the turbo before putting it in the car, it makes like much easier.
Here are a few pictures .
Old Dec 11, 2016 | 07:50 AM
  #73
63 Nova SS's Avatar
Nice! Are you worried at all about pulling in hot air from down around the motor to supply it to the turbo? Probably won't be bad once you get going, but off idle it maybe high.
I wouldn't drive down a dusty road either as I'm sure dust and grit wouldn't be good for that compressor wheel. Looks good!
Old Dec 12, 2016 | 12:32 AM
  #74
SS_Bananna's Avatar
Nah I'm not worried about it, has to go through the intercooler anyways .
Old Dec 12, 2016 | 12:38 AM
  #75
SS_Bananna's Avatar
UPDATE!
Finished up tonight! Took my time on it today and made sure everything was perfect!
Overall, the Hahn kit works great, and fitment was awesome. 2 bolts where hard to get to, but still manageable.
The only thing I had trouble with is figuring out the best way to clock the turbine and compressor size to line up clearanc for the oil feed and drains, and also for the upper charge pipe to connect.
As you will see in the picture, it sits a little crooked, but I plan on changing that out for a better one soon.
I'm pretty sure I'm the first LNF in the country with Hahn's new setup on their car and running! Ready to start tuning on this basemap and make some power!
