ZZP Major Build
#101
Well just a few updates on the major vvt issue. I have it narrowed down to a few different possible causes. I think there is either oil blockage, may have stretched timing chain and jump time or maybe the cam actuators. We run a quick log on the car and the intake cam never moved off 0 and exhaust only moves from 0 to 0.2.
#103
Sounds like a typical ZZP build, I swear one day people on here will realize they are not everything they are cracked up to be.
They make decent parts sure...but I wouldn't trust them to build me a car or even a motor.
My buddy had a short block built by ZZP, it blew up, he took it apart and one piston had all the ring gaps lined up in a row. That was obviously the piston that failed.
Another guy I know who had ZZP build him a motor, gave it a once over upon receiving it to make sure everything was done properly. Ended up having to pull the motor apart since there was numerous assembly errors.
But will people listen? Nope.
Even this guy, ZZP builds him a car....thing doesn't work properly and has all kinds of issues. Everyone blames him and not ZZP.
That makes a lot of sense.
#105
Most people who have issues contact them and they take care of them. But all the people who bitch and complain and slander them try to do everything themselves and expect a car not to have gremlins and go on the forums to gripe.
I disagree and say THEY ARE everything they say/cracked up to be. As one of, if not their highest hp customers who has the highest chance to break something. ..why is it that I haven't had all these problems?
#106
My buddy who had the short block built did contact ZZP, they told him he abused the engine and that is why it blew up. He sent them a picture clearly showing all the ring end gaps lined up on one piston and the damage it caused, they still claimed it was abuse and refused to do anything for him.
The other guy is a bit of a special case, he knew how to properly assemble a motor but lacked the time to do so. After the motor came back improperly built, he just decided to re-build it himself rather than risk it again with ZZP.
These people didn't even go on the forums and bitch, they just cut their losses and moved on with life, I'm simply bringing them up as an example because people never hear about them.
As for gremlins, if I am paying top dollar to have my car built by a shop I would expect a car in return free of any major gremlins cause afterall, that is why you are paying "professionals" to build the car. They should know what they are doing and do it right the first time.
I don't doubt they can build something right, so perhaps you got lucky there, what I'm saying is seemingly everyone I know who has dealt with ZZP has had very bad experience, from the guys I know who had their valve springs snap, to my buddies motor with the piston rings, to the guy whos motor wasn't assembled properly.
I'm glad you have had a good experience, I'm glad for everyone who has had a good experience with them...I really am.
But they will never get a dollar from me based on the way they have treated my friends the quality of product they sold them.
#108
But you're using a few of your buddy's instances to make a judgement on a bunch of guys who do quite a bit for the community and are excellent people to work with and talk to.
As far as paying professionals... Dude, do you know how many AMS GTRs have 'gremlins'? There are ALWAYS unforeseen things that can happen, or go wrong. People make mistakes, sometimes things get lost, etc. ANY and EVERY shop you go to, there will always be a a few cars with some sort of minor (sometimes major) issues. Whether it be tuning or mechanical, and its not always the shops fault. Every car is built differently as well.
My car has been there numerous times, and things are always done right. I don't consider it luck in the least.
Its okay if you don't want their products, and have had bad experiences with them. Some people have. They'll get by, I'm sure. :P
#110
[QUOTE=newt;7173918]Sounds like a typical ZZP build, I swear one day people on here will realize they are not everything they are cracked up to be.
Rings spin r/t the crosshatching of the cylinder. There are points in which they will all line up no matter what you do.
#112
I haven't said anything to anyone about zzp. I haven't even tried to contact zzp as of yet bc they prolly wont stand behind it any way bc im not the guy who originally built the car and footed the bill.I purchased the car as is and brought this thread back up in case anyone was wandering what happened to the car or where it went.
#113
Wow! This thread is amazing. I'll start by saying that this is the first that I heard of issues with this car. No, the customer did not contact me about any issues at all.(edit- he did email asking about a bolt that he wanted to replace) Just before he left our shop, we discussed fine tuning his setup over email by hp tuners.
Second- I can't believe what I read here:
From the sounds of this, the customer was cranking the boost who knows how high because he thought the boost was not going up. I assume he was easily past 30psi, maybe over 35 if he kept trying to turn it higher. Then to top it off, he unhooked the regulator stlye boost controller which was clearly connected properly according to his post above. Then he proceeded to hook it up wrong and then continue to drive the car. At this point, he still had not contacted me about boosting issues. And yes, he had my email address.
Lets take this a step further. I went back and read all of our emails to make sure I wasn't missing anything. I found an email from him that started out:
I responded by providing him with a config file for his hp tuners. He later sent a couple more emails asking questions, and never once mentioned a boost problem and never sent a single scan. Then months later I am reading on a forum about how we wouldn't help him. Amazing.
So I'm getting ready to make a big post and put up a few vids of the car ....
However I'm dissatisfied with couple things I'll get into on my next post... I do have a question for you all!
I'm working on turning my boost up a few pounds (its turned down from my high dyno runs) and can't get the boost controller to cooperate. It looks hooked up wrong actually..
For those of you who have hooked up a zzp boost controller with a tial wastegate here is the question.
The top of the wastegate is hooked up as follows - Turbocharger vacuum to MBC to top of the wastegate
The bottom hole is hooked up as follows - Lower IC piping straight to the bottom air hole on the wastegate.
From what I read the correct way is to hook up a MBC straight from a boost source (Turbo or IC piping) to MBC to bottom wastegate hole and leave the top vented....
Thats a lot of babble, let me know if you guys understand, I have Term2 helping with tuning and he has told me nothing in the ECU is restricting boost, it sounds to me like its just running on WG pressure and the top hole is doing nothing..
Hey Matt,
My name is xxxxx xxxxxxx, I picked up your email from Tim. I thought I would give you a heads up that I would be sending a scan log soon. I wanted to see if there is anything in-particular you wanted to see.
#115
#116
Plus he watched us dyno his car, adjusting the boost as we went. How does he figure it got hooked up "wrong" on his way home?
#120
But why not email me? He emailed to ask for a bolt which is self explanatory, but then he takes it upon himself to reconfigure his boost controller the wrong way!
#122
Also, anyone who makes the statement, "I'm working with so and so to fix this..." (with the so and so not being zzp) will almost always fail. There are just certain guys that develop a solid relationship with zzp and work with us exclusively if there are any concerns. These guys have the fastest cars and the fewest problems. Then there are others who immediately go to the forums or a different shop or member to try to work things out, and typically their car is never right again.
#125
I sent you a pm. Old owner hasn't had the car since mid part of July. I bought it in first part of Aug. I have not bashed zzp nor do I plan to. Lets move on to fixing the car the way it needs to b. I haven't talked to any one else's shop nor has it been to any one else's shop. I haven't even put I wrench any where except to replace Turbo bolts that were falling out 2 weeks after I had it. U have my contact info in the pm.
