Color matched SPRAY PAINT from GM!
#77
no not unless you have a paint and baking booth. you will not get the same effect as if is professionally done. they add a flex additive to the paint so that the part can bend freely without the paint cracking. but if you do want to try you will need 4 cans not 2.
#78
Two quick questions on this guys....
1. Does this spray not require a clear coat as well. Is it just spray and your done?? ( I have a very small amount of chipping in the front of my fender due to it being low to the ground, and me hitting a few curbs)
2. Those who have ordered a can, how long does it take to arrive?? I noticed it said special order on the website. Does it arrive fairly fast or are we talking 2 weeks plus here?
Thanks guys
Thanks guys
#80
Thanks guys
Thanks guys
#82
Heres all the colors for our cars and the spray can part #'s so you can order them from any GM dealer.
BLACK (41U).............................12345119
OLYMPIC WHITE (50U)...............12345205
VICTORY RED (74U)..................12345539
YELLOW (34U)...........................12346642
LT TRNISH SILVER (67U)...........12346694
CASMERE MT (15U)...................12346726
EMERALD JEWEL MET (38U)........12346798
LASER BLUE MET (21U)..............12346786
SUNBURST ORANGE MET (56U)...12346722
ARRIVAL BLUE MET (91U)...........12346648
MAJESTIC AMETHYST MET (84U)..12346219
ULTRA SILVER MET (95U)............12345305
PACE BLUE (20U).......................88860746
SPORT RED MET (29U)................12346746
Now these are the color names but I would STRONGLY suggest you double check your paint code against the (--U) next to the color to be sure you ask for and order the CORRECT color! GM does change names but paint codes never change, always go by the paint code even if it has a different name. Again paint names can change from year to year and model to model but paint CODES DO NOT!
Note: these are 5oz. cans of color matched paint from GM, not aftermarket! These are the absolute closest you will ever get to matching your cars color.
Any questions?
Any questions?
Any idea of the paint code for the silver interior trim on uplevel and SS models?
#85
#89
As for the silver, it looks like it'll just have to be some trial and error with some automotive spray paint until the correct match is found.
#90
I pumped that code for black into gmpartsdirect.com and ended up with a can of clear coat instead of black. The code matches up but, I think they might have changed the code for black since that post? Not sure if anyone else ran into this problem but i figured id give a heads up.
#100
Might be my NoScript application for Firefox, we'll see.
That's what I was doing too, but, never get any results.
-shrug- I can call, I guess.
