GmPp clutch still available for lnf Balts?
Old 05-18-2016, 11:22 PM
cjdz24_Z28's Avatar
I need a new clutch for my 10 Cobalt SS but after a quick search I can't find one. does anyone know where I can find one?Thanks
Old 05-19-2016, 12:30 AM
Sl0wbaltSS's Avatar
You're doing it wrong lol. The GMPP clutch is for the LSJ cobalt not the LNF lol.
But it works JUST FINE on the LNF and holds more than stock.
Zzp has a kit and flywheel for cheap on their website.
Old 05-19-2016, 05:58 AM
63 Nova SS's Avatar
Crate engine depo also sells them. And yes you can use the gmpp on an Lnf, I am running one.
Old 05-19-2016, 09:33 AM
yellowsupercharged06's Avatar
just note that the GM flywheels are priced very high .. the zzp flywheels are cheap Chinese flywheels now
Old 05-19-2016, 09:50 AM
Administrator
Administrator
Staged07SS's Avatar
Translation... do not purchase ZZP flywheels.
Turbo Johnny (08-07-2019)
Old 05-19-2016, 10:33 AM
advise's Avatar
get your factory one cut
Old 05-19-2016, 05:36 PM
BlackMagic's Avatar
been hearing stuff like this about many of zzp's parts as of late. Are they going to the cheap side with everything lately or has it now become common knowledge that this is what they are doing?
Old 05-19-2016, 09:45 PM
Tdubbs's Avatar
I went with the GMPP from CED, and paired it with a LuK LFW285 flywheel. No problems so far after 1k miles. The stock clutch **** out on the dyno at 77k miles at 322whp/334wtq slipping like crazy. I didn't stick it back on a dyno but had Dave finish the tune on the street. I can't give you exact numbers but it definitely is holding more than the last dyno run.
cjdz24_Z28 (05-24-2016)
Old 05-19-2016, 09:52 PM
Sl0wbaltSS's Avatar
I'm pretty sure zzp doesn't use some cheap flywheel. It works fine for me. Never had an issue.
Scythe_Snake (05-20-2016)
Old 05-19-2016, 09:56 PM
Def interested in the flywheel you used, please keep an update going. I'm about to buy one just to throw on a shelf for when I need to change my clutch
Old 05-19-2016, 10:12 PM
exninja's Avatar
Probably the same as zzp's
Old 05-19-2016, 10:20 PM
Tdubbs's Avatar
Idk about the ZZP one, but the LuK part is stamped made in Germany. Looked exactly the same as the factory one coming out when I laid them side by side. I still have the factory one, thinking about getting it resurfaced and holding onto it for a backup.
Edit: ECaulk, I'll try and do a long term review of the combo as I get more miles on it.
Old 05-20-2016, 12:59 AM
exninja's Avatar
OK, I had done a search for that and the part on Amazon came up and listed it as made in China. So who knows?
Old 05-20-2016, 08:50 AM
Tdubbs's Avatar
The pictures are hard to make out, but mine looked exactly like this one.
http://www.autopartswarehouse.com/sk...LUKLFW285.html
Has the LuK logo, made in Germany, and part # stamped into the backside. Now I'm not saying that there aren't some made in China, it's possible, but I got the one pictured. Like my edit said for ECaulk, I'll try and make a long term update how this part combo works and we'll see how viable the LuK part is.
Old 05-20-2016, 02:58 PM
Scythe_Snake's Avatar
Hey guys,
Just wanted to clear up stuff. Our flywheel is not 'some cheap china stuff' as said in the thread. Our flywheel IS an OEM flywheel. We are able to save on it, and are therefore trying to extend that to you all as well. So much so that we are having trouble keeping them in stock.
Deathshead (05-20-2016)
Old 05-20-2016, 03:57 PM
exninja's Avatar
Originally Posted by Scythe_Snake
Hey guys,
I don't care much, but the description on your website literally says "This is a new aftermarket OEM replacement flywheel." So which should I believe?
Old 05-20-2016, 07:28 PM
By that I get its a new aftermarket with oem specs flywheel
Old 05-20-2016, 11:00 PM
exninja's Avatar
Aftermarket OEM spec is very different from OEM. Usually OEM spec means it fits.
Old 05-20-2016, 11:07 PM
exninja's Avatar
If it is a legit OEM flywheel I'd suggest changing your verbiage on the website. I've done business with you and i was very pleased so I have nothing against you. This post just seems like misrepresentation with how the wording is on the website.
Old 05-24-2016, 05:50 PM
cjdz24_Z28's Avatar
Thanks I ordered the kit from Summit and had them price match so it came to 283.99 shipped. I also plan on going with the Luk Flywheel. Anything else I need? Alignment tool?
Old 05-24-2016, 06:21 PM
Tdubbs's Avatar
Clutch alignment tool, clutch pipe, distribution/bleeder block, flywheel bolts, and possibly pressure plate bolts. The pic on Summits site shows only the TOB, PP, and clutch disc. If you had bought it through CED you would have gotten the clutch pipe, alignment tool, and the PP bolts for the same price, then all you would need are the flywheel bolts, and the distribution/bleeder block.
Edit: It should come with the PP bolts, but it might not.
Old 07-05-2017, 06:35 PM
ionRL_585's Avatar
Hey guys,
hmm...I just got one and it said made in china..?
Old 07-13-2017, 03:19 PM
ionRL_585's Avatar
well even though it was from china I've had no issues yet! I have a stock LNF Flywheel for sale if anyone is interested.
Old 08-02-2017, 06:31 AM
Dutchman's Avatar
How much for the stock fly wheel? I'm about to have my clutch replaced
Old 08-03-2017, 09:15 AM
ionRL_585's Avatar
pm sent. Just to let you amd everyone else know it is used.
Quick Reply: GmPp clutch still available for lnf Balts?
