Dyno Results Dyno pictures, videos and dyno results.
The Official Dyno Thread 2015
Old 09-23-2014, 11:23 AM
  #101
user 72239's Avatar
Leemanfor Dyno
344 whp 457 ft lbs
Intake, Catless Downpipe, K04 turbo, E85, Upper CP, Intercooler, Lower CP, BOV.
Old 09-23-2014, 11:53 AM
  #102
BlackMagic's Avatar
Leemanfor Dyno
344 whp 457 ft lbs
enough torque to twist an oak tree
Old 09-23-2014, 12:11 PM
  #103
InfraRedline's Avatar
Went to the local Dyno Dynamics to play around a month or so ago. My 508whp pull on the Dynojet on 23 lbs at 7300 rpms made ~460whp on this dyno. I ran out of WG spring on this run after it spiked 28 and held 27. It's all better now
517whp/417wtq
ZZP 2.1/TK s259et/PH/C/E/RS/115s/E85/27psi
Ramp rate was set low and were doing 3rd gear pulls, as I don't care to load the car in the lower rpms over and over on a dyno, so don't mind the late appearing spool.
Just to show how it spools on the street, here is 19.5 lbs before 3700 rpms in 4th gear
Old 09-23-2014, 12:48 PM
  #104
armcclure's Avatar
Sweet
Old 09-23-2014, 12:53 PM
  #105
Administrator
Administrator
Staged07SS's Avatar
Update: 9-23-14
leemanfor
infraRedline
and myself added!
Old 09-23-2014, 01:19 PM
  #106
South Central *********
JapEatr's Avatar
Yay!!!
Old 09-25-2014, 06:16 AM
  #107
kjgcobaltss's Avatar
2.0 lsj
T/160s/rs/tk/c/pi/e85/fs/pte6262 616whp 519wtq. Dyno jet dyno
Old 09-25-2014, 07:09 AM
  #108
CobaltSS 16's Avatar
**** man.....nice ^^
Old 09-25-2014, 09:42 AM
  #109
jonathan923's Avatar
damm sick numbers!^^^
Old 09-30-2014, 09:56 PM
  #110
Wert842's Avatar
Originally Posted by kjgcobaltss
2.0 lsj
Hey you, I like that ****.
Old 10-01-2014, 10:57 AM
  #111
armcclure's Avatar
Still kinda surprised by the hp vs boost, but there's a lot of factors that play into that.
Old 10-01-2014, 03:58 PM
  #112
Having stock head ports did not help any lol
Old 10-01-2014, 04:04 PM
  #113
I think that is a big factor in your numbers too. But regardless, it did make that power on the stock ports, which is impressive. I'm sure you started seeing diminishing returns as you cranked up the boost and it restricted more and more. You'll be able to turn the boost down considerably and make the same power on the new build
Old 10-01-2014, 05:06 PM
  #114
BlackMagic's Avatar
Not sure why I never posted this before but this is from about two years ago now.
conditions were pretty much a worse case scenario being that it was 104*F and humid that day. I want to toss it back on the dyno this fall to see if it has more in it.
(Lysholm 1600ax)
TS/3.25/1000s/I/H/DP/T/HE/BRFPS/E85
Old 10-02-2014, 07:14 AM
  #115
Administrator
Administrator
Staged07SS's Avatar
(Lysholm 1600ax)
Nice man!
Old 10-07-2014, 01:35 AM
  #116
SSfamilywagon's Avatar
Not bad at all for the size pulley used on that blower
Old 10-07-2014, 09:50 AM
  #117
100% METH's Avatar
Very close to the power I made on that blower with the same pulley w/o e85 and the fuel system.
Old 10-08-2014, 04:44 PM
  #118
how come those twinscrews were never a hit? They seem to make better power then the TVS. I'm guessing its because its not a direct bolt on and most dont want to fab something to make it fit.
Old 10-08-2014, 04:49 PM
  #119
LNFTX's Avatar
Awesome looking graph
Torque plateau
Old 10-09-2014, 09:18 AM
  #120
100% METH's Avatar
More money than a TVS for minimal gain
Also the the people making them for whatever reason would always drop the ball after a kit or two.
Old 10-09-2014, 12:08 PM
  #121
got it... who did you sell yours too? lol
Old 10-09-2014, 01:22 PM
  #122
100% METH's Avatar
Never owned it
just did the tuning
I think the 1600ax i tested was eventually sold to blackmagic
Old 10-09-2014, 06:32 PM
  #123
I think me and 100% Meth here were talking one day about the Twinscrews and it took bigger the a 1600 to be as efficient as the TVS is if I remember right
Old 10-10-2014, 09:00 AM
  #124
100% METH's Avatar
If you're going to go bigger, stay in the TVS family
The provided graphs show the TVS is more efficient in the rpm range we take them to
Old 10-19-2014, 07:01 PM
  #125
kcc140's Avatar
310 whp / 271 wtq
I/H/DP/E/T/HE/80s/M62/2.6/PH/PB/E85
Quick Reply: The Official Dyno Thread 2015
