The Official Dyno Thread 2015
#103
Went to the local Dyno Dynamics to play around a month or so ago. My 508whp pull on the Dynojet on 23 lbs at 7300 rpms made ~460whp on this dyno. I ran out of WG spring on this run after it spiked 28 and held 27. It's all better now
517whp/417wtq
ZZP 2.1/TK s259et/PH/C/E/RS/115s/E85/27psi
Ramp rate was set low and were doing 3rd gear pulls, as I don't care to load the car in the lower rpms over and over on a dyno, so don't mind the late appearing spool.
Just to show how it spools on the street, here is 19.5 lbs before 3700 rpms in 4th gear
517whp/417wtq
#113
I think that is a big factor in your numbers too. But regardless, it did make that power on the stock ports, which is impressive. I'm sure you started seeing diminishing returns as you cranked up the boost and it restricted more and more. You'll be able to turn the boost down considerably and make the same power on the new build
#114
Not sure why I never posted this before but this is from about two years ago now.
conditions were pretty much a worse case scenario being that it was 104*F and humid that day. I want to toss it back on the dyno this fall to see if it has more in it.
(Lysholm 1600ax)
TS/3.25/1000s/I/H/DP/T/HE/BRFPS/E85
(Lysholm 1600ax)
#115
(Lysholm 1600ax)
(Lysholm 1600ax)
