Dyno Results Dyno pictures, videos and dyno results.
The Official Dyno Thread 2015
Old 04-09-2015, 11:50 AM
  #201
cblt2469's Avatar
09cobaltss1 they arent as bad as they look, i think his AFR reader was bad, because on my scan gauges its much more stable than that reads, he was just using a sniffer to get the AFR idk if thats normal or not. but its much much more stable than that shows.
Old 04-09-2015, 12:21 PM
  #202
Administrator
Administrator
Staged07SS's Avatar
Tailpipe sniffers arent very accurate... so if your wideband shows an ok afr, I'm sure you're fine.
Old 04-09-2015, 02:52 PM
  #203
09CobaltSS1's Avatar
When you say scan gauge, is this a graphed curve or just glancing over by eye in the middle of a pull? Also, do you have an independent wideband or are you basing this off of the on-board lambda sensor? The on-board sensor is generally good, but just bare in mind, they can and do fail periodically. Yes, I've seen them have issues. Either way, I'd find a way to graph your afr curve vs your trims and see how they look just to be certain everything is in check.
True, they tend to read lean, but they'll at least read consistently lean. Generally they're within 3-5 tenths of your actual afr curve, not all over the place like what his chart is showing. Granted, the sniffer could clearly be off, but god help anyone getting a dyno tune relying on data readings from that thing. lol
Old 04-12-2015, 10:12 AM
  #204
CobaltSS 16's Avatar
CobaltSS16, 288whp, 250wtq, Verified Dynojet, 2.7/80s/I/H/DP/CD/E/HE/E85/PB/T
Old 04-12-2015, 11:22 PM
  #205
armcclure's Avatar
Oh heck this whole time I thought you were on civilian fuel. Seems more reasonable now
Old 04-13-2015, 07:07 AM
  #206
Administrator
Administrator
Staged07SS's Avatar
Very nice!
Old 04-13-2015, 09:15 AM
  #207
Nope corn juice my friend
Very nice!
Thank you sir... once you update my new numbers you can take me out of #13 spot on M62 list... that was my old setup. thanks
Old 04-14-2015, 07:10 AM
  #208
Administrator
Administrator
Staged07SS's Avatar
Yep, will do.
I'll be adding the new dyno posts this week.
Old 04-14-2015, 09:31 AM
  #209
Really nice numbers im jelly.
Old 04-14-2015, 10:27 AM
  #210
Administrator
Administrator
Staged07SS's Avatar
Title changed to official dyno thread 2015.
Still contains all the other dyno information. So keep posting in here guys.
Old 04-15-2015, 12:45 PM
  #211
Administrator
Administrator
Staged07SS's Avatar
Update 4-15-15
Shaneman
cblt2469
CobaltSS16
Added.
cblt2469 please provide the jpg. link in your post so I can copy and paste it into the list. Thanks.
Old 04-21-2015, 11:36 AM
  #212
InfraRedline's Avatar
Well heres an update of what I've been up to the last couple of nights. I'll update this graph when I get my dyno load control fixed so I can load it up to spool more like the street instead of in inertia mode where it hits 30+ lbs by right before 6k. Numbers won't be affected though. I also need more WG pressure since it falls from 34 psi to around 32, but even so you can tell the turbo is just starting to fall out of its efficiency range with the small .55 AR hotside. I'll make a thread in a couple days with lots of pulls on different boost levels so you can see the progression and curve changes as I turned boost up. Another cool note is that last year on the Dynojet at MAP in MN on 23 lbs I made 508whp running out of fuel at 7300, and two nights ago on the same boost and a full pull I made 512 whp, so its really consistent.
So now for the goods
InfraRedline - 650whp/551wtq Dynocom. ZZP 2.1/TK s259et/PH/C/E/RS/160#s/E85/34psi
Old 04-21-2015, 11:58 AM
  #213
yellow dragon's Avatar
Old 04-21-2015, 03:33 PM
  #214
BlackMagic's Avatar
wow that is truly impressive man. Have you tried 34psi on the street? Does it get pretty good grip or is it spin city? I am also jelly of your dyno purchase btw
Old 04-21-2015, 03:43 PM
  #215
I've only done 34 lbs on the street once when my old 1200's were maxed out, but did a few 32 psi pulls. 3rd always hooks as long as the weather is decent and tires aren't cold. 2nd spins but you pedal it and it still pulls hard before shifting to 3rd and hooking. I'm still pretty surprised that the car kept making good gains as I turned the boost up that high. I never expected to make this kind of power. 27 lbs made 565whp to give you a reference on what gains I saw, and 30 made 604whp.
Old 04-21-2015, 03:45 PM
  #216
yellowsupercharged06's Avatar
bigger turbo and nitrous next ? lmao someone needs to knock zzp off the top spot.
Old 04-21-2015, 04:07 PM
  #217
Thats for sure!
Old 04-21-2015, 04:10 PM
  #218
Lol no plans to change up the setup. Just hold more boost up top with some load and flatten the power curve and drive it. Maybe push it a couple more lbs for a glory pull, but nothing major.
Old 04-21-2015, 07:19 PM
  #219
raver0789's Avatar
Wonder if my .63 will choke my s363
Old 04-21-2015, 11:05 PM
  #220
SSfamilywagon's Avatar
Bravo good sir!!! Bravo!!!
Old 04-22-2015, 09:02 AM
  #221
Hoooly sh....
Old 04-22-2015, 10:49 AM
  #222
damn infra... that thing must haul ass.
when are you gonna dyno your baby M62 setup?? That car needs some love... I'm interested in that as well
Old 04-23-2015, 11:33 AM
  #223
Thanks guys! I made over 35 pulls on the dyno from 17 psi all the way up to 34 over the course of 3 days and the car just took it like a champ Didn't even burn a drop of oil. Most of them were 4th gear pulls.
I did the other night. I left the stock catback hooked up and it has a 2.5" catted dp. As it sits it made 292whp. I will unbolt the catback one day soon and do a few pulls, and if needed I'll try a different downpipe off another LSJ on there if it fits. I have no doubts it can make 300whp.
Old 04-23-2015, 11:42 AM
  #224
good stuff
Old 04-23-2015, 03:55 PM
  #225
infra, we should change your username to 650wheelftw
Quick Reply: The Official Dyno Thread 2015
