Disable AUTOMATIC HEADLIGHTS (NOT DRL)
See title. Is the only way a resistor? If so, what size? Do I have to pull the dash out?
My HIDs don't like cycling if I park in the shade....
Thanks!
Thanks!
I believe there is a fuse for the auto headlight side of the system, I haven't looked it up in a long time though...
In order to properly disable it, yes you would have to wire in a resistor in place of the light sensor so the car thinks it's always sunny out. I imagine you could cut the harness down closer to the BCM on the right side footwell, rather than removing the dash.
Constant on and off isn't good for some hid systems either, I can't save I've ever really paid attention to how sensitive the light sensor is for on and offs. I have only always disabled DRL and left the auto on and have had no issue blowing bulbs or ballasts.
I just know HIDs don't like constant cycling. Already pulled DRL fuse. I'll have to play with the light sensor
I was thinking that. I heard if you unplug sensor the auto lights make them stay on all the time
Might sound stupid but what if you just masked the sensor off and plasti dipped it. When i had my truck and i wanted my headlights to just stay on all the time i read up on the whole resistor way and ended up just putting a hat over the sensor lol. Lights never turned off.
That is not what I want lol
what did I miss LOL
The issue is if it thinks it's daylight out... The dash lights won't come on
OrangeK
09-19-2016 08:39 AM
