Jl w7 vs psi
Old 01-24-2015, 03:39 PM
Bthor98's Avatar
Jl w7 vs fi
I have a jl w7 12 at the moment and im loving it, exept for how it doesnt get the lows to well, would the 13.5 jl w7 be better for the lows? And i was thinking of maybe getting a fi, anyone have experience with them? Or is there any other sub out there that can get the highs like the jl w7 and the lows
jl w7 vs FI *^^
Old 01-25-2015, 03:09 AM
EmperorJJ1's Avatar
the W7 is made for the lows. it should play them plenty fine (even thou i dont like the woofer much myself)
what box do you have? pics?
Old 01-25-2015, 04:20 AM
Bthor98's Avatar
Its built to spec off of the jl website and its ported, maybe its because i dont have it properly tuned on the amp yet idk
Old 01-25-2015, 11:03 AM
BoostedLemonPie's Avatar
I bet it's not much tuned under 40hz. My rf power hx2 12 box, I built at 29hz (wAy low!). I'm building a motor I got from an re hc and I'm on the fence on who I want to rebuild it, but most likely psi will. Fi is stupid pricey
Old 01-25-2015, 02:36 PM
Bthor98's Avatar
What do you mean not tuned much under 40hz? How do i make it lower then that? Im new to some of this stuff lol
Old 01-25-2015, 04:16 PM
You'll have to do some research and do some math, or pay somebody to design a box for you with a cutlist for your wood. If it's your first time I suggest you pay for the design, it's very important the person knows what they're doing, a lot of calculations, and the properties of the sub itself, come into major play! And if you go low, you lose the higher frequencies you're used to hearing(40-100) depending, because the box will be tuned for lower hz, so you'll be listening to a lot of decaf and searching for low hz songs. I have a slot port box that is 2.75ft^3. And I forgot my port dimensions, but my spl guru hooked me up with the whole design. He uses psi only...they are local to us here in Memphis.
Old 01-25-2015, 04:34 PM
UltraSilverSS's Avatar
Old 01-25-2015, 09:00 PM
EmperorJJ1's Avatar
in a ported box its tuned to a specific frequency. generally that and a few hz close it it is going to be the peak volume the sub will reach. a sub can still play higher freqs over tuning decently but lower will fall off quickly because theres no pressure and the sub acts like free air. So if you have no lows chances are your box is tuned to high. You would need a new box to be tuned lower
Old 01-26-2015, 12:56 AM
Bthor98's Avatar
K so my box is almost identical to the one off of jl audio, except i didnt have the time to make the walls inside of the box for the port if that makes any sense, would that effect the lows possibly?
Old 01-26-2015, 01:46 AM
cobaltss#01's Avatar
yes.
Old 01-26-2015, 01:49 AM
EmperorJJ1's Avatar
is it ported?
Old 01-26-2015, 02:05 AM
Bthor98's Avatar
is it ported?
Yes
Old 01-26-2015, 03:40 AM
EmperorJJ1's Avatar
then yes it would be tuned higher unless its wider
Old 01-26-2015, 09:33 AM
Bthor98's Avatar
Alright thanx for the help, ill start building a new box ah
Sl0wbaltSS
11-21-2018 11:11 PM
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
SlowSaturn
09-28-2015 11:03 AM
09-27-2015 08:53 PM
Quick Reply: Jl w7 vs psi
