Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
Balance shaft bushings - will you make them for the front?
Old 05-30-2015, 12:29 AM
TurboWood's Avatar
Hello,
I've tried every other contact method for OTTP to no avail so I'm resorting to public requests.
I'm looking for front balance shaft bushings to compliment your existing rear option. Is this something you can make by the end of July?
Thanks,
Daniel
TurboWood is offline
Old 05-30-2015, 09:01 AM
TStone's Avatar
say what? They sell a bushing set, one for where the intake balance shaft, and one for the exhaust balance shaft go
TStone is offline
Old 05-30-2015, 10:37 AM
Blairwolf's Avatar
If you mean the idlers that are made by cutting the balance shafts there is an option on their site to add them to your order.
Blairwolf is offline
Old 05-30-2015, 11:19 AM
ItalianJoe1's Avatar
You're deleting your water pump? That's the normal reason they don't remove the front idlers, most people don't switch to an electric water pump on these cars.
You can get the full bushing kit from Level Zero I believe. Why not just cut the stock shafts?
ItalianJoe1 is offline
Old 05-30-2015, 09:47 PM
TurboWood's Avatar
Cutting the shafts is not an option for me because I'm using the GM racing shorter water pump chain. It uses one of the balance shaft mount holes.
So, I need front balance shaft bushings which is not something anyone advertises. However, I did get a preliminary call from OTTP about a month ago saying they were thinking about it. Since then I've been trying to get confirmation.
Daniel
https://www.cobaltss.net/forums/atta...limination.jpg
Old 05-31-2015, 01:31 AM
South Central *********
JapEatr's Avatar
You can drill and tap the block
JapEatr is offline
Old 05-31-2015, 04:09 AM
TurboWood's Avatar
Please elaborate. I don't see how that will help, but maybe I'm missing something.
Daniel
Old 05-31-2015, 09:42 AM
I think he may be talking about plugging the oil holes with a pipe plug
Slowbalt2000 is offline
Old 05-31-2015, 09:48 PM
Got dimensions? You could have any local machine shop make you a couple sleeved to pop in there for a pretty reasonable price I would think.
I could make them for you but I don't have a block to measure.
Old 05-31-2015, 10:30 PM
cavfiredesire's Avatar
You can buy them from OTTP.....I just bought some the other day
cavfiredesire is offline
Old 05-31-2015, 10:38 PM
Level Zero Motorsports
What you need is the smaller front ones they offer, maybe check with them and see? Everybody who would design them does it to retain the water pump chain, what you're doing is neat but it's a solution but it needs some custom machining.
Old 06-01-2015, 12:20 AM
The smaller ones are just the idler shafts, i understand now what hes asking for and ive never seen it done
Old 06-01-2015, 06:53 AM
TurboWood's Avatar
bingo was his namo...
This is a byproduct of the GM shorter chain. I have to plug the front bearing, not use a cut balance shaft. This way I don't have anything spinning at 14krpm (other than the turbo).
I just wish OTTP would contribute to this thread so I could either give-up on them or have some renewed hope.
Daniel
Old 06-01-2015, 11:25 AM
Get measurements of the front shaft bores and I can make you a pair of sleeves like the ones pictured in the chain pic. I don't have a spare block or balance shafts laying around to measure myself.
Old 06-01-2015, 02:25 PM
just do this, id measure but my spare block is in michigan
Old 06-02-2015, 12:10 AM
TurboWood's Avatar
That is very kind of you. I'll have to get back to you as I'm traveling at the moment.
Daniel
05-28-2022 03:47 AM
06MetallicBalt
08-17-2021 03:40 PM
dennis69
10-20-2015 04:49 PM
SSLOW06
10-01-2015 07:21 PM
Stuff
10-01-2015 05:47 PM
Quick Reply: Balance shaft bushings - will you make them for the front?
