LNF Redemption Build
Old Sep 26, 2015 | 10:53 PM
taintedred07's Avatar
Engine:
2.1 LNF
2.4 gen 3 block
Lnf crank
Ported head
ATI
Deleted balance shafts
Electric water pump
Wiseco 88mm pistons
Molnar rods
Arp head studs
07 Saab 2.0 F40 6 speed manual transmission
ZZP F40 swap kit
Cutch/flywheel to be determined
Lsj brake swap
Turbo
AGP S257 FMW Billet
Compressor Specs:
- Borg Warner 57mm / 76mm OD extended tip compressor Forged Milled Wheel 65lbs/min
- Borg Warner S2 compressor housing with 4" port shroud inlet and 2" outlet
- AGP Cast 3" V band outlet T3 .63 A/R housing
- Borg Warner 70mm/61mm 2.74/2.42 turbine wheel
Turbo Kit
ZZP turbo manifold
Tial 38mm wastegate dump
ZZP downpipe
Tial Bov
ZZP charge pipes, intake, intercooler
Manual boost controller - to be determined
Fueling
Aem 320 in tank pump
Opel injectors
ZZP Stage 2 Cams
5th injector kit - to be determined
Currently the car has a stock lnf long block, 4.45 transmission, gmpp clutch, airbox with zzp tube, mpx catback exhaust, injen upper charge pipe, stock lower charge pipe, stock downpipe, zzp intercooler, bc coilovers 10k spring rates, stock upper engine mount, powell front trans mount, ottp rear trans mount, ottp upper trans mount, lsj brakes, k04, mild dd tune on 91 octane and 23psi.
The 2.1 is in Japeatrs garage and going to Mongorat in a few weeks for a rebuild. I had oil feed issues that killed a couple turbos and then compression issues. Hopefully it just needs a hone and ring job, as well as balanced and decked to the correct clearance. I'll also be getting the head ported by Josh eventually, atleast the exhaust side anyways.
I have most of the turbo kit and just bought the f40 transmission.
I need the turbo, downpipe, dump tube, zzp f40 swap kit, clutch ect. HOPING I CAN GET THE F40 KIT ON BLACK FRIDAY!!!
This is a winter-spring build, but I am in no hurry this time.
A pic of some parts:
Goal
600whp lnf street monster tuned by Area47
Thanks for stopping by!
Old Sep 26, 2015 | 10:58 PM
Haven07's Avatar
Wow...Gonna be an epic build. gl!
Old Sep 26, 2015 | 11:35 PM
LNFTX's Avatar
Hope you have better luck this time that thing will be insane when its done
Old Sep 26, 2015 | 11:40 PM
Me too, but I've learned a whole lot since then and think it's for the best really.
I literally bought an f40 on ebay right before making this thread lol
Old Sep 27, 2015 | 07:44 AM
tuned08ss's Avatar
I thought zzp stopped making the f40 kit.
Old Sep 27, 2015 | 08:22 AM
SR Tech's Avatar
I was wondering what happened with this car, hadn't seen an update in a while. Hopefully there's some suspension parts and tires in the build to put all that power down. Can't wait to see it finished!
Old Sep 27, 2015 | 09:20 AM
They just put it back online in stock, that's what prompted me to get the saab trans right away.
Old Sep 27, 2015 | 09:25 AM
Yea I've been keeping a low profile while going through the issues. That oil feed issue killed that build, a long with financial issues at the same time. But I ordered a ecotec tee fitting that will allow me to get into the oil pressure sensor galley.
And yea, I have bc coils, full mounts, xxx rear sway bar, and powells trailing cabs. Not sure what rims ill be on but it will be for the right tire.
Probably going to do the break in on pump gas, then switch to e85 but we'll see how that all plays out down the road.
Old Sep 27, 2015 | 01:57 PM
cmiller8006's Avatar
Should be a nice and stout set up. AGP turbos are the ****. Little smoky from time to time but good.
Old Sep 27, 2015 | 02:56 PM
I hope so, did you use zzps clutch or aluminum flywheel with your f40?
Old Sep 27, 2015 | 03:13 PM
I was running the fidanza flywheel and zzp's southbend clutch set up.
Old Sep 27, 2015 | 03:54 PM
Ok, that's probably the set up I'm going to go with, I think infa is also on the southbend but dual mass flywheel.
Old Sep 27, 2015 | 03:59 PM
Here's the s257 fmw compressor map
Old Sep 27, 2015 | 05:13 PM
Stage 3, 4, or 4 plus for the southbend, I'm most likely going to end up getting the 4 plus.
Old Sep 27, 2015 | 09:49 PM
Pretty sure I was on the 4+ as well.
Old Sep 27, 2015 | 09:57 PM
Thanks.
So as far as I've heard, you couldn't reach 600whp on full e, with basically all fuel mods and maxing an 80lb 5th.
Is scythes balt just a unicorn or did you have other issues? Do we just need a bigger 5th?
Old Sep 28, 2015 | 12:18 AM
I had the best intank pump, stg 3 cams with race pump lobe, 80lb injector and ran out of fuel just shy of 30 psi. Ryans car, similar turbo specs would make 35 psi, same head, pretty much identical builds except cubic inch. My E85 in summer months usually comes in at 90%, not sure if that's some of it also.
Old Sep 28, 2015 | 04:49 PM
Maybe 1000 or 1400cc injector with a mist spray pattern?
Old Sep 28, 2015 | 04:52 PM
JapEatr's Avatar
South Central *********
funny, I was going to run the 257 as well
Old Sep 28, 2015 | 04:54 PM
What? Since when, before you got the John Deer 256s?
Old Sep 28, 2015 | 04:56 PM
JapEatr's Avatar
no ive been talking to Josh about it, think ill switch after break-in
Old Sep 28, 2015 | 04:59 PM
That is funny, I've been researching this turbo for the last couple months, I'm going with the agp .63 version.
Old Sep 28, 2015 | 08:20 PM
You have nitrous...I don't understand why you're even considering anything below a 62mm lol
Old Oct 14, 2015 | 07:38 PM
574's Avatar
574
In for round 2... If you need a SB clutch hit me up
Old Oct 14, 2015 | 08:02 PM
tomj77's Avatar
Screw 5th injector, install one for each runner. Port and di.
