3rd brake light not working
ok....recently had manual trans out of my 2009 Cobalt SS/TC, now cruise control and 3rd brake light are not working, yes i already ohm tested the bulbs , and the bar itself....showing 6v on my meter at the plug, but lights do not illuminate..... I know from what i have read that the are controlled together.....but by what? I have already scoured the threads and have seen people with similar symptoms but no solutions....help please! also no CEL on the dash either....
i pulled the positive terminal off and that did not work....doest it really matter positive or negative just as long as one is not connected?
Already did. No luck......when I test voltage across the connector at the 3rd brake light with the brakes on I am seeing around 6volts....bad ground maybe? Or is the switching done on the grounded side
royce777
09-28-2015 07:11 AM
