Help! How do I re-align my supercharger pulley?
Old 05-14-2007, 11:12 PM
yellowcobaltss05's Avatar
Like the title says, I am getting major belt squeal from the pulley being about a 1/8-1/16 of an inch off from all the other pulleys. How do I re-align the pulley without taking the hub off?
Old 05-14-2007, 11:20 PM
chevysalesman614's Avatar
is it pressed on too far, or not enough? when you take the pulley off the hub, the hub itself should sit flush.
i think your problem can be solved with a gear puller. rented at pep boys or autozone. it kind of looks like a tripod and will be able to grip on the small hub.
I just had this very same problem. for a quick squeal fix i was using castrol chassis grease.. but then i fix the mis-alignment, and it stopped. but then, my stock belt was no longer sufficient. and i had to go with the stage 2 belt. i think the only thing keeping my belt from slipping was the mis-alignment.. so keep that in mind when you fix this problem (your belt may be stretched)
of course you are running a 2.5" pulley, so i guess you have the oversized tensioner
Good Luck!
Old 05-15-2007, 12:47 AM
Good Luck!
It is pressed on too far. So if i rent this gear puller i can make the hub/pulley straight with the rest of the pullies by gripping the hub and pulling it back away from the snout to align with the rest of the pullies? And no im not running an oversized tensioner
Old 05-15-2007, 12:55 AM
you have to take the pulley off of the hub, and align the front of the hub with the end of the shiny stick that comes out of the s/c (IDK what its called . lol)
Old 05-16-2007, 12:35 PM
hey do you think i could put washers beind the supercharger pulley when i put the bolts back in to move the pulley forward a tad bit or would that be a bad idea?
Old 05-16-2007, 11:47 PM
Coblasts's Avatar
I wouldnt use the washers.
I think that would be trouble.
To bad it wasnt the other way it would be alot less trouble.
Old 05-16-2007, 11:50 PM
beercan's Avatar
I would be extremely careful with that gear puller .. because it puts pressure on the shaft and pulls against the hub to pull it off. So If you arent careful you will push your shaft back into the supercharger too far. If you go that route .. take it really easy
Old 05-17-2007, 03:36 AM
well i fixed it by placing washers behind the pulley to bring it out more and wallah no more belt squeal
Old 05-18-2007, 02:17 AM
ptrblkz24's Avatar
Id fix it the right way man.You might be putting stress on the pulley bolts now that it doesnt sit flush with the hub.How thick are the washers?Did you put slightly longer bolts on?With the washers there,you probably lost a few threads on the bolt and they might break.Fix that **** the right way and dont ghetto rig it.Youll be sorry if something breaks because of something stupid like that.
Old 05-18-2007, 08:25 AM
Your right the bolts I am using are probably the wrong ones. I am going to order the bolts from ZZP
Old 05-18-2007, 01:26 PM
Coblasts's Avatar
Its not worth doing it like that in the long run,if those bolts shear off who knows the damage the belts going to do when is tangles and jams into the other pulleys or
super charger free spins at red line.
Spend the money and fix it right or better yet go see the guy who installed it wrong in the first place !
Old 05-18-2007, 01:31 PM
rlinbatonrouge's Avatar
It's not worth commenting here.
Yes it is. Fix it right before you kill yourself, please.
Old 05-18-2007, 01:35 PM
bc3tech's Avatar
**** that - leave it
Old 05-18-2007, 01:48 PM
lol i have the wrong bolts in the hub which is probably making my pulley off aligned so we'll see what happens when i put the ZZP bolts in and if its still not lined up then im going to kill myself jk
Old 05-23-2007, 05:29 PM
ok i got the new bolts from ZZP and the damn thing is even MORE to the right of all the other pullies. Besides the gear puller does anyone know of something that can grab the hub and pull it away from the snout a little bit?
Old 05-23-2007, 05:45 PM
GSoccer24's Avatar
not true...that puller doesn't push in on the S/C shaft it pushes against it for leverage. i used it on mine with no problems whatsoever. it's only an anchor point.
Old 05-23-2007, 05:51 PM
How exactly do you use a gear puller to pull the hub away from the snout?
Old 05-23-2007, 06:05 PM
ptrblkz24's Avatar
how did the bolts make it worse?The pulley is supposed to sit flush on the hub.I dont see how the bolts will push the pulley in further.Ur best bet is to remove the s/c and bring it to a machine shop,and have them remove it and reinstall it.Or buy/rent a puller and do it yourself.I have the zzp puller and it worked like a charm removing the stock pulley.
Old 05-23-2007, 06:10 PM
GSoccer24's Avatar
it will most likely mar the threads in the S/C shaft, but there is a middle shaft on the puller that presses against the S/C shaft, which is threaded and screws through the body of the puller. the puller then has 3 arms that grab behind the hub, and as you screw the middle shaft of the puller, the arms pull more and more until it pops off or starts to slide off the shaft.
10-20-2015 09:56 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
z28addiction
09-28-2015 12:03 AM
ChrisTutoki
09-24-2015 08:39 PM
Quick Reply: Help! How do I re-align my supercharger pulley?
