Forum Jump Gallery Social Groups vBLive Garage Register Now Videos Link To Us Store Site Map TSBs
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Vendor Forums
Go Back   Cobalt SS Network > General > Problems/Service/Maintenance
Sign in using an external account
Register Forgot Password?
Home Regional All Albums   FAQ Members List
LinkBack Thread Tools Search this Thread Display Modes
Old 10-02-2007, 12:41 AM   #1
Points: 6,236, Level: 51
Points: 6,236, Level: 51 Points: 6,236, Level: 51 Points: 6,236, Level: 51
Level up: 44%, 114 Points needed
Level up: 44% Level up: 44% Level up: 44%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Member #: 1528
Check out my gallery  Check out my vbgarage
I need some help with brake lights
first off i have 2005 2.0l SS. Now my prob. I tried to change my pedals to aftermarket (momo), half finished when i relized just my third brake light was on didnt really think much about it at the time. Just disconected the batt. while i finished cutting the gas pedal (which i had removed, im sure this has caused my prob.) Re installed gas pedal thinking this would make everything normal, but thats not the case!. right now my thrid brake light is on and will NOT turn OFF !! I have no brake lights when i step on the brake? does not matter if car is running or off, keys in ignition or not, third brake light will not go off? plz any ideas on what ive done or how to fix? thanks
anyone?
bump for some help
jkn04 is offline   Reply With Quote
Old 10-02-2007, 12:47 AM   #2
Member #: 5462
Images: 15
did you mess with your brake switch at all when you were under there? Also check behind the insulation and everything where you bolted the pedal back up to see if you pinched any wires. Sounds like you have a short somewhere. Check your brake light fuse and make sure it's not blown
__________________
06 Cobalt ls
yea it's slow
Novajoe is offline   Reply With Quote
Old 10-02-2007, 10:58 AM   #3
Activity: 0%
Member #: 1528
morning bump
Old 10-02-2007, 11:02 AM   #4
Member #: 12136
Quote:
Originally Posted by jkn04 View Post
brake light fuse is good, when headlights are on tail lights work just dont get brighter when i step on the brake. If it was the brake light switch would'nt all the brake lights be stuck on ? But it would go off when the car was turned off i think? THIS THING WILL NOT GO OUT unless i disconect the batt? im confused
yes if it was the brake light switch they would all be on unless the second filiment in the bulbs is burnt out so only the thrid brake light is showing, it happened to me in my neon (my first car) from the brake lights being on so long the ones on the ends burnt out from the heat they created and just the third on worked haha
so replace those bulbs and if there all on then the brake light switch is stuck
hope that helps any
shane =)
__________________
Chevrolet Cobalt SS Supercharged
Mods to Date:
K&N cold air intake, Tsudo cat-back, Custom catless downpipe, Ingalls TD, 2.6 Pulley, #60 injectors, Stage 2 belt, Really Really bad custom tune, Tenzo R springs, Stewart Warner Boost, Oil press and Voltmeter gauges, Aeroforce interceptors and a few others...
SKDR112888 is offline   Reply With Quote
Old 10-02-2007, 11:27 AM   #5
Activity: 0%
Member #: 1528
Im at work right now will check the blubs when i get home, has anyone changed there brake light switch? is there any tips or tricks i should know? Just in case i find myself changing this tonight.
Old 10-02-2007, 01:35 PM   #6
Points: 5,044, Level: 45
Points: 5,044, Level: 45 Points: 5,044, Level: 45 Points: 5,044, Level: 45
Level up: 47%, 106 Points needed
Level up: 47% Level up: 47% Level up: 47%
Activity: 0%
Member #: 11358
Images: 4
Send a message via AIM to ssaddiction Send a message via Yahoo to ssaddiction
it has to be a spinched wire or the brake light swich...or you could have hit something(pinched wire or something to the the brake light switch react) that jolted electricity to the brake lights and instead of blowing the fuse it fried the second filament on the lights since they come on when you turn the headlight on but dont change when pressing on the brake pedal anyway goodluck figuring it out and keep up posted on what caused this to happen
__________________
2006 RECARO BLACK SS/SC W/G85
GM Stage 2, Exedy Stage 3 Hyper-single, Nates 2.9 Polished pulley(thanks nate), Injen CAI, Hahn 3''Catback, Ingalls Engine Dampener, 15% Tint, NGK BKR7E's, DC Sports Strut Bar, Debadged, Exedy HYPER-SINGLE Clutch
ssaddiction is offline   Reply With Quote
Old 10-02-2007, 02:13 PM   #7
Points: 4,942, Level: 44
Points: 4,942, Level: 44 Points: 4,942, Level: 44 Points: 4,942, Level: 44
Level up: 96%, 8 Points needed
Level up: 96% Level up: 96% Level up: 96%
Activity: 0%
Member #: 16657
Send a message via AIM to Misery5567
Must resist Satan.....
You cannot resist...
CHECK THE BLINKER FLUID!!!
But seriously, I agree with the burnt out bulbs and a stuck/shorted switch
__________________
Misery5567 is offline   Reply With Quote
Old 10-02-2007, 02:40 PM   #8
Activity: 0%
Member #: 1528
Topped up fluid first did not help, but good call lol Will update this when i solve the problem. But for now im sitting at work stewing on this!!!
Old 10-03-2007, 08:42 AM   #9
Member #: 12136
and MAKE sure your keys are in the ignition and on cuase the middle brake light will come one weather or not your keys are in the ignition or out, as long as your hitting the brake, but the other brake lights (as stated above) only come on when your headlights or on or just when ever you turn the key in the ignition,
__________________
Mods to Date:
Old 10-03-2007, 03:43 PM   #10
Activity: 0%
Member #: 1528
Talking
Yes the keys in the ignition thing, is one thing i did not know so that solved that issue. Did a search and found out that from someone who was having a similar prob. The other problem i figured out was the retainer clip (cheap plastic) for the brake light switch was stripped switch is good slightly stripped will replace both. So a $1.40 retainer clip caused all my prob. I guess when drilling my brake pedal i pulled back on the pedal too hard, and popped it out. Thanks for all the info/help the switch will be here thrus. so i will be up and running again by the evening
CobaltSS
Chevy Cobalt
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
brake lights Lespaul350 Modern Performance 3 08-21-2007 05:59 PM
New GM rotors??? EvlPeanut Suspension 14 07-19-2007 04:59 PM
Flashing led brake lights Stouffer General Cobalt 4 05-21-2007 04:53 PM
Brake lights staying on? O5CobaltSS Problems/Service/Maintenance 7 01-27-2006 04:07 PM
e-brake/parking brake Nightcrawler Suspension 20 07-15-2005 12:19 PM
vBulletin copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Admincp backup
