P0016 Crankshaft Position
Old 08-24-2007, 05:18 PM
FuzzzMan's Avatar
P0016 Crankshaft Position - Crankshaft Position Correlation Bank 1 Sensor A
Eny body seen that errer before??
My care spit out its 1st CEL the other day and thats what it told me.. when I fisrt saw the light I check my airfilter to find the rubber boot on the Injen airfilter was torn and I may hav been sucking Sh|t up the pipe... could that be the cause?
Old 08-24-2007, 05:19 PM
madmark's Avatar
may just be that the crankshaft position sensor needs to be relearned
Old 08-24-2007, 05:20 PM
Psykostevo's Avatar
Sounds like you should try a Crankcase Learn.
I have only seen this error on cars with improperly installed cams, or those that swap computers with another car. Weird that yours would throw a code like that.
Old 08-24-2007, 05:22 PM
FuzzzMan's Avatar
Ya I thought it was odd aswell.... I have no internal mods and allways go to the same dealer... Is there a way i can do the Crankase lear myself?
Old 08-24-2007, 05:23 PM
Psykostevo's Avatar
No, but your dealer can do it in 5 minutes with a Tech2 and a CanDi Module.
Old 08-24-2007, 05:24 PM
madmark's Avatar
no you have to have the tech 2
FuzzzMan's Avatar
should be a warrantee thing NO??
Old 08-24-2007, 05:28 PM
madmark's Avatar
it should yes.
Old 08-24-2007, 05:40 PM
FuzzzMan's Avatar
You guys are awsome... Thnks much...
OK cant get in till teusday AM.. and they couldn't tell me if it was safe to drive or not because they had no idea
hacadacalopolis
10-28-2015 06:09 PM
cw383
09-30-2015 12:41 AM
Extreme Dimensions
09-24-2015 07:51 PM
Extreme Dimensions
09-24-2015 05:24 PM
Gugi96
09-15-2015 12:24 AM
Quick Reply: P0016 Crankshaft Position
