rough idle / random misfire w/ low gas
Old 09-26-2018, 06:33 PM
Johnny Bliss's Avatar
car seems to idle worse and kinda run worse part throttle with the gas around 1/4 and lower. cant' tell a difference at wot.
anyone ran into this before. i get the random misfire code a lot with the 60s but i also got it with the 42s, but it seems to go off after i fill up and after a while comes back on
anyone seen anything like this before? i put a new fuel filter on it a while ago but ive never done anything with the pump or checked pressure
Old 09-26-2018, 09:10 PM
ProfDNS's Avatar
First thing that comes to mind is sediment, but that only happens when you get bad gas which is pretty uncommon. Try running a can or two of Seafoam on your next 2 fills ups and see if there's any improvement.
Old 09-26-2018, 10:15 PM
I'll try I did fule injector cleaner several times but I don't think it's very powerful.
Top end is all new too
Old 01-04-2020, 05:24 PM
Car still does this tried a lot of stuff... Must be the tune???
Old 01-07-2020, 08:29 AM
jdbaugh1's Avatar
I'd think fuel starvation problems would to cause you problems at WOT instead of low demand situations like you are experiencing. Are you throwing any codes besides misfire? I wonder if faulty EVAP system could potentially cause those symptoms.
Old 01-07-2020, 02:49 PM
I tried a new evap solenoid on the motor but not the one in/ by the tank....
I wonder if it's the cheesy intake I have making it do this???
Has any of the china intake copied a good one yet??? 200-300 bucks for some bent pipe is outrageous
There are eBay ones that look pretty close for 50-70
Old 01-07-2020, 03:54 PM
jdbaugh1's Avatar
Intake could easily throw your MAF reading off. Not because it's a bad intake but because the MAF is sensitive.
Old 01-07-2020, 06:48 PM
bahoodle's Avatar
if u put the maf in backwards the car wont even run if that says anything haha. did u put the brand of intake into the order when you bought the zzp canned tune?
Old 01-07-2020, 06:55 PM
Yeah I did.
It's one of those short aem things with the upper part being the stock plastic pieces
Old 01-07-2020, 06:56 PM
Looks like this
Old 01-08-2020, 08:23 AM
jdbaugh1's Avatar
With the MAF that close to the end/air filter your MAF readings could definitely be skewed especially with the bend right before.
Old 01-08-2020, 05:12 PM
i bought a new ebay intake. it has a nice flat spot before the MAF i'm going to give it a shot for $50.
Old 01-09-2020, 07:41 AM
jdbaugh1's Avatar
You don't have anyone that can tweak your tune or at least take a look?
Old 01-09-2020, 10:31 AM
No, it didn't have this p0300 until I got the 60s and tune it's either intake or tune related. The hesitation between gears shifts was fixed when with new tune and injectors but then the p0300 started at idle.... There was no cell with the gm stg 2 but it did run crappy. It runs great now except the idle misfires which you can only really tell by the cell
I think someone is going to buy it today tho for 4000.
I'm looking at a 04 gto for 8000 that's pretty nice
.well see
Old 01-09-2020, 09:03 PM
Sold cobalt the gto was a POS
PyroMechanic
03-13-2014 05:00 PM
d.maggard
02-24-2012 12:29 AM
rocketman2005
02-02-2011 12:44 PM
obsessed212
12-20-2010 01:58 PM
2fastforyouraSS
06-08-2008 08:30 PM
Quick Reply: rough idle / random misfire w/ low gas
