Speed Sensor Question (ABS light on)
Old Jan 19, 2009 | 10:33 PM
Tazmanian_Dvl's Avatar
Exclamation Speed Sensor Question (ABS light on)
OK so I have a question. I have a 2006 SS/SC and my ABS light is on. The hard codes in the computer are for Right Front Speed Sensor and Right Front Speed Sensor Erratic. I have the 5 year/60,000 mile warranty on the power train (I have 42K and change on the ODO) and wheel bearings are covered under the power train warranty. Here's where my questions come in.
1. Are the speed sensors part of the wheel bearing/hub assembly on the SS/SC's (I'm 99% sure they are)?
2. Those of you who are GM techs what do you think my chances are of getting the repair warrantied if the speed sensor is part of the wheel bearing assembly itself?
3. What else could cause these codes? BCM? Wiring?
4. Does anyone have the GM part number for the wheel bearings or speed sensors (if they are separate) so I can look for prices online?
Thanks guys! Any thoughts would be appreciated!
Old Jan 20, 2009 | 12:06 AM
Cobaltss/TC's Avatar
Well the sensor itself is part of the hub. Though you might want to check the harness that loops up around the steering knuckle, i have seen plenty of cobalts that have cut wiring with both of those codes, the harness isn't that expensive either.
Old Jan 20, 2009 | 12:16 AM
Sumasianluv's Avatar
my guess is a short
Old Jan 20, 2009 | 12:19 AM
FZWCobalt_09's Avatar
same thing happend to me but my abs would actually turn off.
Old Jan 20, 2009 | 01:08 AM
yea when the ABS light comes on it shuts the ABS off completely.
I"m 99% sure it's the hub assembly/speed sensor. I remember hittin a pot hole pretty good a week or so ago and i know that can wipe the speed sensors out. I'm just hopin I can get this covered under warranty...
Last edited by Tazmanian_Dvl; Jan 20, 2009 at 01:08 AM. Reason: Automerged Doublepost
Old Jan 20, 2009 | 11:04 AM
bump for a GM part number. I would like to search online for it incase I end up having to buy it. Thanks!
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Extremespeed
Sep 29, 2015 04:34 AM
z28addiction
Sep 28, 2015 12:03 AM
