brembo pins are stuck help me!!!
my pins will not come out :'( do u guys think i need new calipers? er should i try cutting grinding then drilling the pins out :/
so im thinkin about getting a little torch n trying again but b4 that i read that if i poor boiling water on them that i may b able to get them out? idk im thinking about trying that b4 using a torch on em :/
believe me i know now.. ive only had the car since november last year ive done the back brakes twice since they get stuck pretty easily n i tried doin the fronts but had no luck i just gotta torch n ordered pins from zzp so hopefully i have some luck this weekend when they get here :/ now what do u mean cut em out with a dremel? like using a mini cutoff wheel wit a dremel? what do u do after that did u dril it out or punch it out?
well i took the caliper off cut the pins w/ a sawzall n the front ones came out easily w just a vicegrip holding them n a hammer but the backs i had to heat up pretty good n beat the **** outta them til they came out :P i actually bent the one pin but then i was able to get vicegrip on it to get it turnin so i sprayed it w pb blaster while turning it cut it n then it came out. the inner pad was seized to the caliper and they were brembo pads so idk if theyve ever been changed lol
So, I won. I spent 3 hours on 2 calipers, pulled without removing the caliper and any damage.
but of course there was a magic device
Last edited by Kostyhhrss; 06-15-2018 at 09:46 AM. Reason: https://m.youtube.com/watch?v=XYj8Nr0mHWc&feature=youtu.be
