what's needed
what's needed
I'm piecing together my own "Stage" kit. I want to use your 2.9 pulley. I'm stock right now. What additional parts do I need besides the pulley and new screws to get the factory pulley off and get your pulley on? Do I need a pulley puller or a different snout? Thanks in advance.
Question answered.
If you're currently stock what you'll need is a complete modular pulley system and a puller/install tool...here are the links...
Complete modular pulley system on the bottom half of the page
www.smoothflowpulleys.com/Stage2.html
Pulley Puller/Install Tool
http://www.smoothflowpulleys.com/Pulley_Puller.html
You don't need a new snout, the pulley system hub is pressed on the same way as the stock pulley so all you need to do is use the puller to remove the stock pulley, then use the threaded shaft/nut assembly to press the new hub on.
Thanks for your interest!
Iceberg
Sep 29, 2015 12:33 PM
