Control Arm Bushing???
Old Apr 29, 2009 | 10:06 PM
sschik's Avatar
My control arm bushing just went its the front driverside. What should i do get the poly or just get the stock and would i need to change the driver and passenger? Car is a 06 SS 2.4L I'd also like some tips on some suspension upgrades want to drop the car about a 1". Thanks in advance..
Old Apr 29, 2009 | 10:50 PM
qwikredline's Avatar
contact Josh at OTTP STAY AWAY FROM POLY CABS....they are dangerous
Old Apr 29, 2009 | 10:53 PM
ItalianJoe1's Avatar
Agreed, the poly ones are crap and don't last at all. Stock or ball joint style would be great.
Where in FL are you BTW?
Old Apr 30, 2009 | 12:32 PM
DaBuzzard's Avatar
Stock for the quietest ride, spherical (ball joint style) for the best handling. Decent roads I would go spherical. And ya, the poly ones should be illegal imho. They fail and things get real ugly real fast
Not sure on springs but the Eibach kits seem to get good reviews. Your SS with FE3 won't get quite as much drop as an LS/LT with FE1 would so keep that in mind when comparing. Not sure what suspension the vendors are using as a baseline when they spec a 2" / 2.5" etc drop.
Oh, and if one needs replacement I would just do them both. Unless you hit a pothole / curb/ whatever, the other side will not be long to follow.
Old Apr 30, 2009 | 03:37 PM
Omnigear's Avatar
i thought fe5 is the only
one that works with sphirical
Old Apr 30, 2009 | 05:42 PM
DaBuzzard's Avatar
Ummm, ya, thats what I meant
Can you swap the fe5 control arms into fe3 / fe1 cars? Pricey I'm thinking but.....
Old Apr 30, 2009 | 06:10 PM
you are right. here is one solution. If you buy the spherical cab deal from OTTP I can install some in some good used FE5 alloy arms for $100 additional the pair of arms. That is only if you are a Josh cusotmer, and buy the cabs, and I can install them for you. Add 5 bucks if you want ball joint heat protectors if you are auto xing...
one time deal and better than an Fe3 arm you could put the cabs in a steel Fe3 arm but it would be like putting a turbo on a Lada
Old May 1, 2009 | 12:42 AM
IsItFast?'s Avatar
Well that wouldnt be so bad if it was this lada - http://www.youtube.com/watch?v=DNwNPJAgv3M - - all you need is 100-200k and the engineers from Lotus to do it .
Old May 1, 2009 | 02:05 PM
DaBuzzard's Avatar
Damn, that is sooooo tempting. Few cutbacks at work lately so I am trying not to spend much right now. Got to crunch some numbers, maybe the wife won't mind if she doesn't get new drapes just yet
That is too funny
And only 100,000 pounds Sterling? A pittance
Old May 4, 2009 | 04:11 PM
Maven's Avatar
The Cobalt FE3 arms are alloy, not steel, they should take the OTTP CABs no problem.
Old May 4, 2009 | 04:32 PM
DaBuzzard's Avatar
Just got a whole lot more tempting.....
Old May 4, 2009 | 04:36 PM
SS4ME's Avatar
I'm no expert but wouldn't that be a little harsh for daily use?
Old May 4, 2009 | 04:38 PM
G85 SS's Avatar
Get in contact with Josh(fast98) or Sean(lsjwannabe) from OTTPerformance.
They'll point you in the right direction for what you need done.
Old May 4, 2009 | 06:00 PM
Not at all. I ran a custom set I made in my car for a while and loved them, really made the front end tighter, much better response through the steering, more road feel. Great upgrade. Only real downside is the higher cost than the stock setup and the increased maintenance depending on your climate, they may squeak or whatever, mine never did though.
Old May 4, 2009 | 06:54 PM
SS4ME's Avatar
Okay cool. It may be a mod I consider in the future but Wisconsin roads are a potholed mess but there are some good roads around that I would have to stick to. Plus I would have to have something other then my SS/SC for a winter car because salt would kill that set-up quick I would think. Hopefully I'll have my wifes old car for a beater when see finally decides on what car she wants to buy.
Old May 4, 2009 | 11:36 PM
Maven's Avatar
OTTPs CABs are weather sealed OEM spec joints, designed to last the life of a car(not sure what that really is but they will outlast polys at striaght sphericals many times), I live on Southern NJ, Ive got salt in the air year round from the Altantic Ocean and salt on the road as soon as there is a 1/2" snow, these rock.
Old May 5, 2009 | 10:57 AM
SS4ME's Avatar
I'll look into them. Thanks.
DANRICKARD
Oct 1, 2015 12:08 AM
footballplaya3k
Sep 30, 2015 09:39 PM
yellow dragon
Sep 28, 2015 09:49 PM
GBRunner24
Sep 26, 2015 06:44 PM
Coballin13
Sep 25, 2015 08:43 AM
