Nitrous Oxide N20
Want to install n2o
Old Jul 30, 2009 | 10:20 AM
roser4888's Avatar
Question Want to install n2o
I have a 05 cobalt ss/sc and want to install n2o, but dont know what to go with. The mods i have are gm stage 2, cai, full exhaust, stage 2 clutch, and 8lb flywheel. Do i go dry or wet shot? Wjat shot should i use? Can you please give me some suggestions and reccomendations on what to go with. And what i need to do if i install n2o.
Old Jul 30, 2009 | 10:22 AM
scott allen's Avatar
go with a wet shot for sure. and to start off i would go with a 35 shot and that will give you about 50 whp gain. but i would tune for it for sure.
Old Jul 30, 2009 | 10:49 AM
roser4888's Avatar
Is the gm tune ok or i need a different tune? I cant find anyone near me that does a tune on my car.
Old Jul 30, 2009 | 11:12 AM
daythecountrydied21's Avatar
do you have a wideband?
Old Jul 30, 2009 | 11:34 AM
roser4888's Avatar
No im prob gonna get one
Old Jul 30, 2009 | 12:56 PM
i would get tuned.
Old Jul 30, 2009 | 04:29 PM
StreetLC's Avatar
Not to call anyone a liar, but the GM stage 2 tune goes great with a 50 wet shot. I personaly have been running the stage 2 tune and a 50 shot for nearly a year now and have not had one problem. Just make sure you do it right and not half ass and you should be fine.
Old Jul 30, 2009 | 04:36 PM
Cefaln452's Avatar
how so?
Old Jul 30, 2009 | 05:31 PM
ChriSS/SC's Avatar
Really? What would you say about a wet 75? And what exactly are your mods?
Old Jul 30, 2009 | 05:37 PM
ItalianJoe1's Avatar
Stage 2 tune, don't exceed a 50 shot. Especially if you are running a smaller pulley on the stage 2 tune.
Obviously, tuning for the nitrous is the best option, but you can run it untuned if you keep the shot small and the boost reasonable. I've seen a 90 shot on a 2.9" pulley done safely with tuning, and a 75 shot on regular stage 2 pulley with no tune, but a 75 shot on stage 2/2.8" has cracked pistons in more than one car I know off, along with a 100 shot untuned on a stock car.
Old Jul 30, 2009 | 05:41 PM
chris88z24's Avatar
I just hooked the bottle directly to my intake manifold and floor it around. Works great!
Old Jul 30, 2009 | 05:44 PM
06_SIC_SS's Avatar
lol i like this approach
Old Jul 30, 2009 | 05:46 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i was on stage 2 w/ 2.9 pulley, full bolt-ons and 60 shot forever. ran 20 bottles of nitrous through the car like that
Old Jul 30, 2009 | 05:49 PM
zrated89's Avatar
i still would like to see someone run a 50 on a 2.7 with supporting mods. I bet that bitch would haul
Old Jul 30, 2009 | 05:51 PM
I did it on a 2.8" with a little more than a 50. It was fast.
Old Jul 30, 2009 | 05:55 PM
zrated89's Avatar
i plan on getting ottps dyno tune kit and running a 50 on my 2.7. cars makes awesome power now and pulls hard. Im on a custom tune i have a wideband already and an aeroforce. Im just wondering how much timing im running at WOT. I think what ima do is run it see what my AFR's are and see if im getting any KR on the aeroforce.
and was that the setup you cracked you piston on? but you spun then hooked and bogged correct? Also how muchboost were you seeing on just the 2.8? Ive seen 19.2 at WOT in the top of third at the track
Old Jul 30, 2009 | 07:01 PM
StreetLC's Avatar
Prety much same mods as me.....Its a winning combonation
Old Jul 30, 2009 | 07:19 PM
Cefaln452's Avatar
how do are blown motors like n2o?
Old Jul 30, 2009 | 08:52 PM
Correct, I was also running full stage 2 timing when that happened, which I shouldn't have been. I didn't have access to my HPT for a couple months to back it back down after some diagnostic checks, and it cost me a motor.
I was about 17-18 psi tops, I had some pretty decent port work and full cooling done though.
Originally Posted by Cefaln452
how do our blown motors like n2o?
Boost + nitrous is a winner, every time. It has a superior intercooling effect, as the nitrous is something like -150 degrees when it hits the air stream. On our cars, with such poor compressor efficency, the gains from the added cooling make for a much better power gain from a given shot size, although that gain doesn't really increase as shot size climbs. Assume a '50' shot gives you 65whp gain, a '75' shot will gain about 85whp, not 100.
Last edited by ItalianJoe1; Jul 30, 2009 at 08:52 PM. Reason: Automerged Doublepost
Old Jul 30, 2009 | 08:56 PM
Cefaln452's Avatar
say im running a 2.6... would that be too much boost to add n2o also
Old Jul 30, 2009 | 08:57 PM
Cefaln452's Avatar
Old Jul 30, 2009 | 09:03 PM
It's never too much boost, but at a certain point you start to have to trade off more timing to run the larger shots than the extra power is worth. Start with a smallish, 30hp shot or so, tune accordingly. If everything is manageable, bump it up one or two jet sizes at a time, re-tune for it, and stop when you are having trouble finding traction in 3rd or you stop gaining power.
Old Sep 6, 2009 | 12:53 PM
noscoby's Avatar
wet is defently the safest. always start 35 work your way up check plugs and codes. alot of ppl rut 50 wet
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
