Pics of the SS intercooler?
Old Jan 22, 2005 | 09:11 PM
rob's Avatar
rob
anyone have any pics or the intercooler? i think i've seen every pic on the web and every pic in the brochures but no good viewable pics of an intercooler
Old Jan 22, 2005 | 10:18 PM
cvenom2122's Avatar
Wink
its an aftercooler not a shiny looking radiator in front grill, like most
Old Jan 22, 2005 | 10:25 PM
https://www.cobaltss.net/forums/pictures-videos-64/cobalt-ss-%40-dc-auto-show-844/
2nd picture.
Pictures I took at the DC auto show
Old Jan 22, 2005 | 10:51 PM
JonyyB's Avatar
Site Founder
here ya go
Old Jan 22, 2005 | 10:53 PM
rob's Avatar
rob
thanks
thanks a lot guys
Old Jan 22, 2005 | 11:09 PM
JonyyB's Avatar
Site Founder
Originally Posted by rob
thanks a lot guys
That’s why we are here Did you order a Cobalt?
Old Jan 22, 2005 | 11:21 PM
rob's Avatar
rob
yeah
ordered it on the 21st of Jan. these things better get here soon im going insane without a car... EVERYONE STAY AWAY FROM SCION! the tc's are horrible in the rain
Old Jan 22, 2005 | 11:25 PM
JonyyB's Avatar
Site Founder
I take it you had one? The TC is a nice lil car IMO
Old Jan 22, 2005 | 11:32 PM
rob's Avatar
rob
its looks and options.. yeah
just doesn't grip to the ground like it should.. i had one tottalled it, spun out going 40 round a wet curve into a tree. girlfriend did the same thing. they are nice but not good for anything but dry straight roads
Old Jan 23, 2005 | 12:33 AM
EvenStar's Avatar
I've actually heard some bad stories of them in bad weather conditions, my freinds girlfreind totaled one because she skidded going around a curve (sounds alot like ure story lol) and hit a tree. I just don't think they grip as well as they should, thats what toyota gets for trying to make cheap classy cars. Also alot of these stories have swayed me away from scions.
Cobalt all the way
Old Jan 23, 2005 | 12:40 AM
rob's Avatar
rob
yeah..
yeah... and it feels good to step out of the imports into the domestic level.. hopefully ill stay.. but either way ill definitly stay away from scion tc's
Old Jan 23, 2005 | 01:02 AM
Snowman's Avatar
ok...you got it wrong in the pic(honest mistake cause it does look like a front mount).....the silver thing you see is actually just the condensor for the air conditioning..its located right in front of the radiator. The real intercooler/aftercooler is located in #502 in the pic below
The Cobalt doesnt have a front mount intercooler, rather a laminova heat exchanger
unlike the srt-4(which has an air-air intercooler like most turbo vehicles.) The 2.0 LsJ engine has a laminova heat exchanger(fancy way of saying liquid-air intercooler)
So basically inside the manifold they have these little tubes(4 of them) that coolant runs threw to cool the aircharge right before it goes into the chambers.
As seen in the Pic below...also after the pic is a list of what all the nubers are...you will see
(408) Oil Indicator Tube O-ring
(409) Oil Indicator Tube
(410) Oil Indicator Tube Bolt
(411) Oil Indicator O-ring
(412) Oil Indicator
(500) Intake Manifold Gasket
(502) Intake Manifold
(503) Throttle Body Seal
(504) Throttle Body
(506) Throttle Body Bolt
(518) Intercooler O-ring
(519) Intercooler Washer
(520) Intercooler Washer
(521) Intercooler O-ring
(522) Intercooler Cover Gasket
(523) Intercooler
(524) Intercooler Cover
(525) Intercooler Cover Bolt
(526) Intercooler Cover Seal
(527) Supercharger Gasket
(528) Supercharger
(529) Supercharger Bolt
(711) Map Sensor
(726) Supercharger Inlet Pressure Sensor
(727) Map Sensor Bracket
(728) Map Sensor Bracket Bolt
(749) Map Sensor Bolt
rob's Avatar
rob
intercooler
where is the intercooler located? ive looked at the redlines to get an idea, but found nothing, if that is the radiator and not the intercooler than where is it and how big could it possibly be?
Old Jan 23, 2005 | 11:36 AM
Snowman's Avatar
ok...did you even read my post......the intercooler ia about as big as a 1/2 loaf of bread...
its number 502 in the pic i posted.its not big
Old Jan 23, 2005 | 06:24 PM
cs_88's Avatar
Cobalt all the way
HOLY ****!!!!
i didnt know scions were so unsafe? Gee... no wonder i feel safer in a mini cooper or a civic.
Either way that talked me out of a scion, but im still trying to make up my mind.
scions look lioke ass anyway...
Old Jan 23, 2005 | 06:28 PM
cs_88's Avatar
then how come it says: (502) Intake Manifold ??
and is that huge air conditioning unit really necessary?? Looks like they ripped it off a silverado.....
Old Jan 23, 2005 | 11:54 PM
Eddie's Avatar
the intercooler number is 523, it goes into the manifold 502 thus intercooling the air befor intering the cylinder head.
Old Jan 24, 2005 | 01:46 AM
where does the heat exchanger cool it's water down?? Snowman can you get a blow out of that system. I assume the heat exchanger has a radiator mounted somewhere on the car...
Old Jan 24, 2005 | 11:03 AM
turbostang's Avatar
The heat exchanger uses the engine coolant to cool the instake charge, it does not have a separate supply.
Old Jan 24, 2005 | 01:19 PM
Osman's Avatar
if thats the case... first mod on this car should be blocking the engine coolant and running a seperate radiator/pump for thet intercooler...
Osman
Old Jan 24, 2005 | 02:32 PM
turbostang's Avatar
Osman
That is what the Cobra/Lightning guys do, they have the same setup.
Old May 21, 2005 | 09:34 PM
jzchev28's Avatar
crazzy stuff.... should hook the A/C up to the intercooler, that'll get it cold as chit
Old May 21, 2005 | 10:33 PM
Vooduguru's Avatar
You know what's funny,
Old May 21, 2005 | 11:03 PM
JapEatr's Avatar
South Central *********
the IC has its own coolant supply and resivior... read your owners manual, makes good bathroom reading.
Old May 23, 2005 | 12:16 AM
JapEatr's Avatar
so any ideas for a larger IC setup
