Think I have a problem?!
Old Apr 19, 2008 | 10:37 PM
eastcoastz's Avatar
Im not sure if this is the gm tune or not, but for a while now my long term fuel trims always stay + 9 cruising and +14 to 16 when I take my foot off the gas. I NEVER goes - at all. I figured I had an intake leak, but I do not. Replaced the MAF and O2 sensor 1 and stayed the same.
Old Apr 19, 2008 | 10:48 PM
steddy2112's Avatar
Are you throwing p0171?
All that means is that is has to add some fuel...if you aren;t coding I really don't see how it would be a problem
Old Apr 19, 2008 | 10:58 PM
Red2.4SS's Avatar
That just means that the ECM is adding that % more fuel than the "expected" value. It is a normal correction that it constantly does. 14-16% is kind of a lot. You may benifit from a tune to get it closer in to 0.
Old Apr 20, 2008 | 12:06 AM
eastcoastz's Avatar
No codes. Being a tech myself I only see this as the PCM is always just adding fuel. On most cars the LTFTs go + and - 0 to 6. The fact that its always + makes me think somethings up, but since I have the untunable GM Stage 3 PCM I guess I'm screwed.
Old Apr 20, 2008 | 12:12 AM
Red2.4SS's Avatar
It should be +/- 6 max normally. as long as you can confirm the o2 sensor is good and everything is normal you may just need to tune. perhaps use the old ECM and get it tuned?
Mine have been around -12%, with no codes. It is better to be a tad rich rather than lean.
Old Apr 20, 2008 | 12:14 AM
eastcoastz's Avatar
I need someone with the GM tune to verify this.
Old Apr 20, 2008 | 12:17 AM
steddy2112's Avatar
I got mine down to about 8
No more codes...these cars love the warm weather too...first car I've ever had that likes to be hot...
Old Apr 24, 2008 | 10:01 PM
rockkrawler628's Avatar
ive got the gm stage 3 but no tech 2
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
