No power and a flutter sound
Old Sep 28, 2015 | 11:28 PM
turbochargedss2012's Avatar
I been having a flutter sound for about 2 months now it comes and goes randomly. When it is present i cant boost but 2-5 lbs. I ended up getting a CEL with code P2261 bypass valve stuck. So i got a forge bpv and the im still having the same problem, I've tried both the yellow and green springs didnt make a difference. The other day i was backing out of my driveway and it was acting like it wanted to stall. It smoothed out and I continued to go down my road. I then noticed the flutter sound came back once again along with a CEL so i had it scanned and i now have 4 different codes.. P2187 fuel trim lean, P0234 turbo engine overboost, P0236 boost system performance and P2261 bypass valve stuck. Iv checked the vacuum tank its fine. Anybody have any suggestions? Thinking about changing the bypass solenoid next but idk if that will help. Thanks in advance
Old Sep 28, 2015 | 11:43 PM
tomj77's Avatar
its most likely the solenoid, just bypass the solenoid for a run, connect ur bpv line straight to manifold, then plug ur vac tank into the solenoid where bpv was to close the port so u don't have boost leak. u should know in a few minutes if that's ur issue or not. if it works fine, change solenoid.
Old Sep 29, 2015 | 07:09 PM
Jn2's Avatar
Jn2
Sounds like your solenoid. Mine did something similar. My forge started to open during normal driving(-5hg though zero). Then I put the stock one on and would always hear a loud whistle from the turbo, and no BPV sound when letting off the gas in vacuum.
Replaced the BPV solenoid and no more whistle with stock BPV. Put the Forge back on and its no longer opening or sticking open during DD.
Old Oct 1, 2015 | 09:31 AM
I put a new soleniod on and the flutter has seemed to go away but before i had any problems when under full boost and letting off i would hear a very define sound of air now it just sounds as quite as it was with the stock intake.
Old Oct 1, 2015 | 11:20 PM
tomj77's Avatar
That's shouldn't have changes. What intake?
Old Mar 19, 2016 | 03:17 PM
redman2357's Avatar
Anyone know what the solenoid part # is and where to buy? Thx
Old Mar 19, 2016 | 10:01 PM
Ebay item number 111575766855 sold by zzp
Old Mar 20, 2016 | 12:30 AM
no_ss's Avatar
Make sure vac lines are on tight. Had this problem
Old May 29, 2020 | 10:41 AM
Adrian Vest Jr.'s Avatar
Question
Hi I recently bought a colbolt ss turbocharged with a tune and turbo everything done to it but the bov you don’t hear I don’t think even at all or barely what might be the cause to that? Or should I get a new bov that it might help or what might be the issue that I can’t hear the bov ?
Old May 30, 2020 | 04:54 AM
blu3_v1p3r's Avatar
A little more info is needed here. What turbo and other mods.... The stock turbo does not have a BOV, it has a Bypass Valve. In stock form its not very loud, with an aftermarket intake is more noticeable, but still not very loud. If you're on the stock turbo with the bypass valve block off plate, your MAF should have been relocated, and a BOV should have been installed, and tuned properly for it. Maybe start another thread with your mod list and the issue you are having, include information on and check engine lights and things liek that.
Old Jun 9, 2020 | 08:12 PM
tomj77's Avatar
get a aftermarket intake and u will hear it
Old Sep 20, 2023 | 12:17 PM
sunnyvale's Avatar
Has anyone tried using this adapter I found on ebay?
https://www.ebay.com/itm/114185463004
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
Stuff
Oct 1, 2015 05:47 PM
DANRICKARD
Oct 1, 2015 12:08 AM
