Methyl Alcohol???
yep the exact same.......Methanol, Methyl Hydrate, Methal Alcohol all the exact same!
I would recommend against it unless you are in a pinch, windsheild washer does have some detergent in it, best s to go to a hardware store and my a gallon of Methanol and mix with a gallon of distilled water!
If you need to use windsheild washer in a pinch make sure its the -40 degree one! and not summer washer fluid!
Last edited by QuikSilverSS; May 16, 2008 at 03:44 PM. Reason: Automerged Doublepost
I should get mine on Monday. With my current mix I'm max at 21* timing and AITs at WOT about 109-115. I've actually gotten as high as 120. I'll let you know how the new juice goes. I also get some stutter in 4th gear WOT at about 4000-5000 rpms. I'm hoping that the Devils Own mix will help that as well. I may also try spraying earlier.
AIS
Forced Induction
119
Nov 13, 2008 11:56 AM
