What is a clamped MAP
Old Jan 17, 2006 | 04:25 PM
JapEatr's Avatar
South Central *********
i see you guys use the term map clamp for a map after the blower
what exactly is this map clamp, is it really a "clamp"
ive been a mechanic for a number of years and have yet to hear of what this is
teach an old dog new tricks!
Old Jan 17, 2006 | 04:41 PM
vxer's Avatar
I belive its a way to stop the MAP sensor reading past its max voltage. Voltage is clamped at max so the ECU doesn't throw any codes for over boost. IIRC. Usually, there will be some other way to take over from the ECU to handle the extra boost, otherwise its pointless.
Ta, Paul.
Old Jan 22, 2006 | 02:20 AM
Self's Avatar
A map clamp is used to lean out the A/F ratio by making the ECU think that there is less boost than there really is, leaning out the fuel mixture in turn creates more power. Basically what a JET chip does, except a map clamp is usualy adjustable, and much cheaper.
Old Jan 22, 2006 | 02:54 AM
MyFast's Avatar
also a map clamp is not multi point...a safc is a better way to go...self can get into that if he wants too..
Old Jan 23, 2006 | 01:16 PM
Self's Avatar
I'm not too fond of the AFC hack myself.
Old Jan 23, 2006 | 01:22 PM
Brian MP5T's Avatar
Modifying the Signal from the Mass Air To the ECU as a way to tune it away from the factory settings.
Old Jan 23, 2006 | 01:28 PM
Self's Avatar
Does the Cobalt come with a MAP or MAF?
Old Jan 23, 2006 | 01:30 PM
Brian MP5T's Avatar
Well either way, the clamp is the same..
Old Jan 24, 2006 | 02:03 AM
JapEatr's Avatar
both
DarrenGC
Dec 24, 2021 01:55 PM
footballplaya3k
Sep 30, 2015 09:39 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Shane H
Sep 19, 2015 11:28 AM
